2004 Toyota Camry Logo
Choise Bolton Jr. Posted on Jul 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix this problem?
My check engine light came on and this was the code po228 pedal position sensor
Thomas Perkins
Level 3:
  • Toyota Master 15,088 Answers
  • Posted on Jul 26, 2015
Thomas Perkins
Toyota Master
Level 3:
Answers
15088
Questions
0
Helped
3388397
Points
54869
2answers
2008 Pontiac Grand Prix 1125 obd code
P1125 ????
DTC P1125: Accelerator Pedal Position (APP) System
Circuit/System Description
The throttle actuator control (TAC) system uses two accelerator pedal position (APP) sensors to monitor the accelerator pedal position. The APP sensors 1 and 2 are located within the pedal assembly. Each sensor has the following circuits:
• A 5-volt reference circuit
• A low reference circuit
• A signal circuit
2007 Yukon XL - P01121 Throttle/Pedal Position Sensor A Circuit Range/Performance.
P1121 GMC - Throttle Position Sensor Circuit Intermittent High Voltage
This codes has nothing to do with APP - accelerator pedal position sensor . This has to do with the throttle body - TPS throttle position sensor . These have know problems ,the sensor an broken wire at throttle body , an when this happens the cruise control wont work . The throttle works by a DC motor controlled by the PCM - engine computer .
1helpful
How do i fix?
P0122 throttle/pedal position sensor/switch A circuit low input
P0223 throttle/pedal position sensor/switch B circuit high input
P2101 throttle actuator ctrl motor circuit rang/perf
P2104 throttle actuator ctrl sys-forced idle
P2110 throttle actuator ctrl sys-forced limited rpm
Here is the meaning of the codes hope this helps
2answers
Po 122 problem light on had changed sensor problem not fixed trans not shifting right horrible jurks when it shifts.
P0122 is TPS signal low, which could mean you have a bad TPS, or a fault in the wiring or connector. I suspect a bad Throttle Position Sensor.
How to fix p1121 code in dicor 1.4 l disel
P0120 Throttle/Pedal Position Sensor/Switch A -Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A -Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A -Circuit Low Input
,try changing the throttle pedal switch/mechanism on the floor in the cabin
7helpful
2answers
Code p2138
P2138 is Throttle Pedal Position Sensor/ Switch D / E Voltage Correlation. Replace the Throttle Pedal Position Sensor/Switch.Remember to have the set code Cleared from the cars computer, this will turn off the check engine light and reset it. Good Luck and have a good XMASS.
14helpful
2answers
Engine codes p1159,p0431,and p0122.what are they ?how can i fix?
CODE P1159 INTAKE MANIFOLD AIR CONTROL ACTUATOR CIRCUIT MALFUNCTION. CODE PO431 - WARM UP CATALYTIC CONVERTER BANK 2 EFFICIENCY BELOW THRESHOLD CODE PO122 - THROTTLE POSITION SENSOR OR ACCELERATOR PEDAL POSITION SENSOR LOW INPUT.
2answers
I have a 1999 saturn with a p1283 code in it, any help would be of much thanks
This code indicates, "Accelerator Pedal Position Sensor 2 Circuit High Voltage" on your Saturn. Check the wiring at the sensor. If the wiring is good then replace the sensor.
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
