Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Green clean light blinking again. replaced board once
  • 10,515 Answers
Remove the access panel that is below thedoor and you should find the tech sheet that will give the diagnosticsfor the machine. Most of these were made by whirlpool.
Ifyou would like more information, please post the model number from thecabinet. It's on the crevice that the door fits into. Please post itwith extra spaces between the numbers so that our software for deletingphone numbers will not delete it.
They usually look something like this - 106 11 22 33 44 - for a total of 11 digits.
There are some other tricks as well :-
1. Answer by one expert for kenmore dishwashers - Coil heats water to temp also used to dry dishes. Can be reset bypressing (within 6 seconds)HEATED DRY/NORMAL WASH/HEATED DRY/NORM WASH. All lights will flash. THIS IS PROBABLY A FIRE HAZARD. The dishwasherwill restart but quit again next time the heater cycles on. To work onit safely,pull the D/W out (should be 2 phillips screws into thecounter),and leave open the door.This takes the power out of thecircuits,allowing you to safely reach under the very back and find the2 plastic nuts that hold the heater in place.check the wiringconnectors there for heat signs.On mine the wire was burnt right off.If you remove the heater by removing those 2 plasti nuts is easy toreplace and costs about $40. I paid $7 for 1 new plastic nut.Look fortraces of water on floor below-mine dripped a tiny amount(1/2 teaspoon)and was done like dinner. If you remove it the instructions say toreplace it. Look for the servicemans schematic in the paperwork you gotwith the D/W.If wiring looks ok ,Have other issue than elementreplacement.
2. Second solution :- he clean light sometimes flashes and just needs to be reset. To do sohit the keys in the following order. <Heated Dry> <NormalWash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
3. 3rd solution :- Hi, the reason why you are getting the flashing light is because thedishwasher failed to detect a 4 degrees rise in the water temp duringthe first 8 minutes of the cycle. Some reasons for this is a faultyheater, door switch,(heater runs through the nuetral side of the doorswitch), lack of water, d/w not filling correctly, should be just belowheating element. Clear the fault by pressing heated dry,- normal,-heated dry,- normal. This will put you in the diag mode. Just let it doit's thing from there. It would help a lot if you run the hot water atthe tap before starting the dishwasher after you clear the code..hopethis gets you on your way..
Hope i helped you.
Thanks for using " Fixya " and Have a nice day!!
Posted on Jul 12, 2009
There are two green lights blinking at the bottom of the tv. where the power light is..i believe it's the opc lights. the tv shuts of it self and the two lil green light blink...we put the tv power...
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Main board green light blinking at 5 flashing intervals
researched your problem a little, it sounds like a burnt out board. It doesn't look too good for parts either. google your symptoms and you will see a few hits on your exact issue
Jan 29, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Canon ip1800 green light blinks once and orange light blinks three times
try to clean the circuit of the cartidge with dry tissue or cotton cloth with little alcohol if blinking again replace new one black or color catridge
Jan 27, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Jul 27, 2008 | Mitsubishi WS48511 48" Rear Projection...
42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Jun 23, 2008 | Philips 50PFP5332D 50 in. Plasma...
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
