Question about Dryers
Dryer was working when I opened the door to see if clothes were dry then I went to use it agin and it would'nt work
    Problem Solver:
  • 6 Answers
Probably broke little door switch in door look for a little plastic piece proably fell on floor
Posted on Jul 12, 2009
Dryer door opens during drying cycle, had it "repaired" but still opening - worked originally well for about 2 years - but cannot get it to stay closed for the entire drying cycle.
these newer dryers are such garbage with their thin Sheet metal. see if the door is bent by the hinges. Dropping clothes on the doors bend these newer machines. then they don't seat correctly
Aug 05, 2013 | Kenmore Elite HE4 Electric Dryer
Won't start
hi there.most dryers have a door switch which is operated when the door is closed....check that the pin on the door which operates the switch is not broken or out of line....and that the switch is actually working
regards Sir Galahad
Aug 24, 2009 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
