Question about Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar System
It shows the correct depth and then intermittently says a very shallow depth. ihave wipped the transducer and checked it for level and debri. any ideas?
  • Galaxy Glue May 11, 2010
    How deep are you really when this happens? Does it happen at all depths, or only when you seem to get above or below certain depths? What is the bottom like? Soft? Weedy? What software version is the LMS-522 currently running: How to see what software your LMS-522C iGPS is using:
    Press the MENU button twice on your LMS-522C iGPS.
    Select SYSTEM SETUP.
    Select SOFTWARE INFORMATION.
    The software version for your unit is located under the line that says "LMS-522C iGPS" (ex. "Version 2.4.2").
  • 3 Answers
I have this problem as well! Mine is on the LMS 332C
Posted on Jul 16, 2009
Garmin 300c fishfinder will go from correct depth to 0.0 ft while traveling.Have to turn it off and restart. It is on Hurricane deck boat 198. It is located between engine and leveling tabs.
My experience as a user is that turbulence around the transducer can cause mine to flash and the depth to remain static.Is your fault affected by speed? Sounds to me that you have a faulty connection causing the transducer to "not register". I'd check connections and also the integrity of the transducer. Hope that helps...
Best of luck
May 28, 2014 | Garmin FISHFINDER 300C NIC ()
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
Lowrance X-136DF Fishfinder Not working
Hello Keneth,
Is The transducer In Side the Hull Or Mounted On The Transom?
If Inside Remove It And Re Fit It Using Epoxy Glue Ensuring No Air Pocket Between transducer And Hull.
If transom Mounted Replace Transducer.
Hope this Helps
Gordy
Nov 30, 2017 | Lowrance X136df Fishfinder With Dual...
I have had a Garmin 400c Fishfinder on my 20? Intruder for about 2 yrs. While fishing in the ocean last fall , I started getting intermittent false shallow readings on the unit (but the target depth...
Hello. Go to any autoparts store and purchase an aerosol can of electrical contact cleaner. It replaces ozone-depleting CFC's, trichloroethane, HCFC's, perchloroethylene and other carcinogenic chlorinated solvents. It will clean your contacts of corrosion and remove any and all moisture from them. And it will protect them well into the future. I use it everywhere on my craft, and on the trailer.
Spray the product, let it sit for an hour and then spray again. Use a cotton swab to remove any visible crud. Regards, Joe
Jan 12, 2010 | GPS
Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Jul 07, 2009 | Boating
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
Nov 05, 2008 | Navman Fish 4150sx GPS Receiver
Unit showing 88.8 in the LCD window.
Hello geld1. Your problem is the transducer, cable or connector. Check transducer with an ohm meter, flex the cable while ohming the restance shouldn't change. The location and mounting of the transducer could be the main problem. Use the the correct gel film including a secure postion support.
Sep 22, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Depth finder problem
The problem is not so much the flat bottom, although they are prone to this problem. The way the sonic waves have to travel through the water is affected by turbulence, especially by air bubbles and cavitation, and by the transducer actually leaving the water, which happens frequently on flat bottomed boats. The best solution to this is to have the unit mounted through the hull so it is completely flush with the hull surface - often they are mounted with a surface flange on the outside of the hull which although thin still causes cavitation around the transducer at higher speeds. about 14 knots will usually interfere with the accuracy of the readings on most hull shapes - forward looking sonars perform usually better. Another thing to check is that the transducer is actually seating right in the housing, if it is not flush with the flange then you have problems - even half a millimetre is too much. check no muppet has painted the transducer with antifouling paint - that never helps, also check if there is a build up of marine growth on or near the transducer - a smooth hull will always keep your depth working until a higher boat speed. if the transducer is growing stuff itself then gently scrape it off - be really careful not to scratch the surface. There are now available non-sonic depth sounders, especially ulf radio signal devices, but I have heard no good reports about them, last i saw they were very expensive and maybe they experience other problems at high speed. there also have been towed devices available that may suit your needs better, although probably a lot of trouble in shallow waters. If you can borrow a waterproof video camera, you could mount it behind (not too close) the transducer, this would be a pain to do, but it may give you an insight into what part of the hull if any is causing the problem (tie the camera to the top of the boat securely in case the mount fails) Hope this helps, sorry but your dealer is not totally wrong :)
Sep 25, 2006 | Lowrance M68C GPS Receiver
Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar System Logo
563 people viewed this question
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
dduncan54
dduncan54
Level 1 Expert
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
