Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
New internal hard drive not showing up
I just installed a new seagate barracuda 750GB drive in my Power G5 and it is not showing up on the desktop.  Is there a driver I need to install or a step I'm missing?
im using it yesterday i shut it down after.then the next day it wont detect any hard drive.i put it into other pc and same thing happen.i bought a new one and it works.what seems to be the problem with my 1st hard drive?ty in advance.
  • madjestic Nov 24, 2007
    I just installed a new Seagate Barracuda 160GB/7200.10/ST3160815A HDD as a slave hdd and it is not showing up on the desktop. Is there a driver I need to install or a step I'm missing?My Windows OS XP Pro SP2,try to BIOS update and check the cable connection,but still doesn't work!
    I am using a 40-pin, 80-conductor cable, attach the blue connector to the motherboard, the black connector to the master drive, and the gray connector to the slave.
  • 1,006 Answers
Posted on Nov 16, 2007
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
Interface seagate barracuda 7200.7 200GB drive sata to usb 2 forum
Hello. You are correct that there are no jumpers, however, when you connected the SATA cable to the Internal hard drive, did you notice there were two similar connectors. One was for the SATA the other, longer one is for the POWER for the drive. If your SATA to USB has both connectors make sure they are both installed properly. Be careful you don't break those little plastic tabs because they are not warrantied. If the drive does have power and spins up then it may not be initialized (formatted) and will need to be initialized using START, Administrative Tools, Computer Management, Disk Management. or just click on start and type diskmgmt.msc in the RUN box.
Hope this helps..
Nov 04, 2012 | Seagate Barracuda 7200.7 200 GB Hard Drive
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
Lags and says has bad sector after 14 months
Good day sir/maam, hi, 14 months is too short for a hard disk operating span, what we do is run the diskmanager software that comes with the seagate hard disk, on the diskmanager menu, run the low level format which usually removes the bad sectored space out of the way, and mark it as not usable. then may I suggest you partition your hard drive to 2, one for windows and the the other for data. call your computer dealer if they have in house techs for service, or get the copy of disk manager for your seagate. Hope this helps, thanks
Nov 04, 2009 | Seagate 750GB BARRACUDA SATA 7200 RPM 32MB...
I installed a new hard drive and crashed
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Mar 29, 2017 | Seagate 250GB Barracuda 7200.10 ATA-100...
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Go to Start----Control Panel----Add Hardware  and go through the detection wizard. You also need to name the new drive by right clicking on My Computer and press Manage----Storage----Disc Management. The new drive should show up without a letter for the drive. Right click on the new drive and choose Change Drive Letter And Paths. You can also format it there too if you havn't already.
Oct 30, 2007 | Fantom Drives 300 GB Hard Drive
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
308 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
