Question about Panasonic PT-40LC12 40" Rear Projection HDTV
How to change fuses
I turn on my tv after i changed the lamp and the ;ight just keep blinking green.
  • Gigi74 Nov 23, 2007
    I was getting a message for several weeks that my lamp needed to be replaced. I kept putting it off, until one day, the tv shut off by itself! When I tried to turn it back on, the light just kept blinking green. I replaced the lamp a few days ago but the set is still not coming on!! Just a blinking green light : ( I called Panasonic and they walked me through reseting the lamp meter (turn volume down while simultaneously holding the PIP button down for 7 seconds) but it didn't work! I've checked all the vents but there's no clog! I can't figure out what's wrong!!! HELP!!!
    Problem Solver:
  • 13 Answers
I'm sory sure why did you change the lamp? mybe the lamp was non put in straight and the door safty switch was not right. need more info. WHAT WAS THE SIMPTOM BEFORE YOU CHANGED THE (HOPEFULLY DLP TV YOU ARE WORKING ON)
Posted on Nov 17, 2007
Sony tv model kds-60a2000
Please count the amount of blinks before it pauses. The number of blinks will say if the door isnt latched all of the way or if the thermal fuse has popped above the lamp area. Hope its a 6 blink as that is the thermal fuse which is easy to bypass or replace.
Sep 20, 2016 | Sony Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My tv turns for a couple of minutes then truns off by itself...the red light blinks on and the green light that say timer and lamp also how do i fix it?
The projection lamp on this tv,when was it was last change?The last time change was about 1 1/2 or 2 years,and tv on an used at 4 or 5 hours a day.The lamp life is over,require a new projection lamp.
Jul 10, 2010 | Akai PT61DL34 Television
I turn the tv on the green light blinks 5 times and the red light blink 6 times
this isn't a solution, I have the same issue. Mine started doing the 6 red blinks yesterday. How do I fix it? I've changed the bulb before...
Jun 18, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
When i turn on 3lcd wega engine tv the green light blinks for about 30 secounds and the lamp light blinks continously aNd tv never comes on
change lamp.the lamp # is XL2100U THE BEST PRICE IS IN LAPTOP FOR is complete lamp & housing $93.95
Feb 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Dec 06, 2009 | Televison & Video
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
