posted by ricles on Nov 15, 2007
when i turned on the computer i was shocked because of the spark from my 350watts power supply then i did'nt hesitate to open it to see what kind of ic is been damage and i found 2 ic's that are leaking... what will i do?? buy new 1 or try to repair? if i repair can u give me an ic. for replacement?
Solution #1
posted on Nov 15, 2007
no. not only is it cheaper in the end to buy a new supply, but there are most likely more parts (which may be hard to locate without special equipment) nuked than only the transistors. so buy a new one.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Intel 350-Watt Power Supply
Email this problem
Email this problem
Can you Help with these System Power Supplies problems?
Power Adaptor for 500GB LaCie...
Hi, My LaCie 500GB Porsche USB... Answer This...
Lanier VoiceWrite EX won't come...
The on/off button will not work... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
