Question about Logitech MOMO® Racing (96328204043) Wheel And Pedals Set
Onthe plug is the center pin + or -
I know it is 24 v but on the plug is the center pin + or -
  • 118 Answers
Center pin is +
if your trying to get an adpater this will work---
http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryid.11228000?WT.ac=sc|downloads||dd&resid=KmmwPQoBAkYAACwFfi4AAAAN&rests=1247957262203
they use the same power supply.
Posted on Jul 18, 2009
How to program 110123-130 24 hour timer
1) Copy following link to how to set FM1 series 24-hour timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
2) With your timer, move override button to center position.
Each pin located around edge of dial represents 15 minutes.
Move pin outward for ON, and inward for OFF.
Set current time by rotating dial until current time appears on clock face.
http://waterheatertimer.org/pdf/Armstrong-FM1-timer.pdf
3) Include photo in your question so expert can see timer and make possible identification
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 03, 2012 | Hardware & Accessories
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Do you need a 24 power plug? for this motherboard? http://www.supermicro.com/products/motherboard/P4/E7210/P4SCi.cfm and if not how do i connect it then with a 20 power plug?
Its better if you have 24 pin power plug. If you don't have you can use 20 pin power plug also.
Insert the 20 pin leave 4 pin blank it will work.
May 05, 2011 | SuperMicro P4SCI-RETAIL (NEWITEM17006569)...
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
Nov 18, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
System won't turn on but when i pushg down on one side of the power suply connectore the fan starts running but computer stioll won't turn on it used to boot up then opne day stopped
It sounds like you have a faulty connector - I would return the item under warranty. Otherwise, if it is out of warranty, you will have to source a new motherboard.
Nov 23, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Refilling f4280
You can know it just by using pin or something like this, insertinginto a hole on the cartridge, when you pull the pin off you can noticewhat color is on the pin. You may use tissue to see what color is onthe pin :)
My Amazon Kindle Ebook Reader 's Blog
May 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Won't turn on with new power supply
Sounds like the switch is out to me or it is mis connected to the motherboard
May 02, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Serial interface cable for my 320
I have that very same camera and the male jack is a stereo headphone 3.5 mm style with hot-insulator-hot-insulator-ground as you see normal stereo headphone jacks. The opposite end is a serial female receptacle 9 pin that plugs in as the old serial mouses did. I don't know where you'd obtain such a cord or the proper pin-out diagram, but that is what it operates on.
Sep 08, 2008 | Polaroid PhotoMax Fun 320 Digital Camera
Power Supply Question
hi you can buy a new 20 pin to 24 pin adaptor from ebay for a few pounds, or most new power supplys do have a 24 pin slot for your motherboard power let me know if you need anymore help regards steve,
Mar 18, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Logitech MOMO® Racing (96328204043) Wheel And Pedals Set Logo
55 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Alun Cox
Argospete
Argospete
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
