Question about Emerson Smartset Clock Radio
Time projector Is anyone having problems with the projector not showing all of the numbers.This is the best part of clock for me and i got it from QVC a year ago
  • SGCASE Dec 29, 2007
    I have the exact same issue. It appears to be unable to display the furthest digit on the left. for instance if it is 12:01 it displays fine on the clock but projects 2.01 on the ceiling. even one of the dots is missing from the colon.
    It look as though Emerson is putting out junk.
  • sonogal Jan 01, 2008
    mine shows all 8s, and AM twice (one reversed), so obviously all characters lit. on/off doesn't work, its always on. color choice (blue/green/red) just dims, blue being brightest. something is skrewy in the wiring.
  • 814 Answers
This type of display malfunctions is usually in the led segments operation or the drivers ic's. This may just be a matter of intermittent contact points. The repair would be to re-solder all suspect solder joints connections. The problem could also be with the components becoming defective. This would require a replacement of the defective part. This is best done at a service center where they will have all the parts and service information. You can call the Emerson Customer support at this telephone number 1-800-909-1240. Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you understand the problem and possible solutions for the Clock/Radio's display. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
Mitsubishi XD300U projector projects only black and white
How long have you owned the projector? Once I have all the information I can recommend the best solution please don't reject my solution until then as I know you will find me more then helpful.
Sep 01, 2008 | Mitsubishi XD300U Multimedia Projector
I have a Brookstone radio that has no model number but in addition to the radio has fastened on the side a projector for showing time and temperature on the ceiling. The projector has gradually lost...
Hi, would love to help you out,will be difficult with out what you need to do is to, contact the manufacturer.
I would suggest you contact the manufacturer of your Brookstone radio via phone or e-mail and request for the service manual from them or help. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Good luck.
Jun 10, 2011 | Brookstone Audio Players & Recorders
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Clock theme
just go here put your query here
/ and find best result fot downloading theme for sony ericssson
Mar 08, 2009 | Sony Ericsson K530i Cellular Phone
The clock does not show the correct time.
[] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer web page for the pdf copies of the SmartSet Clock/Radios. You will need a pdf reader and writer to read and make a copy of the owners manual for yourself.Find the make and model number of your Clock/Radio. The instructions for resetting the time after changing the battery will be in the manual. I hope this information helps you with your problem. Than you for using FixYa and have a nice day.
Jan 02, 2009 | Emerson Smartset Clock Radio
Day light Savings time problem
Hi ... I have the same problem ... I found this link but I haven't tried it out yet ...
Oct 27, 2008 | Emerson Smartset Clock Radio
Time Projector problem
The reason these projection displays have problems is usually caused by over expanded solder joints. This is caused by heating in the circuit,through prolonged use. This causes the metal in the solder joints to expand. This expansion will eventually cause the joint to loosen. The join because of the combination of expansion and vibration eventually loses contact with the circuit board connection.The problem is usually easily repaired by resoldering the cold solder joints. This type of problem occurs in all types of electronic devices. When this type of repair does not fix the problem, it is because during the process of becoming faulty it has taken it toll on other circuitry in the circuits of the leds. This is usually the power supply circuit for the leds. This will require the replacing the defective components, like transistors and ic's. This is usually best handled in the service centers. They will have all the service information and parts for the repairs. The customer support telephone number for Emerson is 1-800-898-9020 you can call them between the hours of 9am-5pm CT. Give them the make and model number of you Clock/Radio and ask them for assistance.I hope this information has help you understand the reason for the problem with your Clock/Radio. Thank you for using FixYa and have a nice day.
Sep 21, 2008 | Emerson Smartset Clock Radio
Problem w/ "Cable In" connection socket on Mintek DTV-373-D 37" HDTV
I am having a problem with my DTV-373 also. I called QVC customer service and they gave me a number to call for service. My unit is under warranty also. When you call this number one of the promts is "Press 1 if you bought your product from QVC". The person will take your name and address. They will send a repair kit to your house. When you receive the kit you call the number back and they will send a service person to your house to fix it. Mintek has gone bankrupt but this service was hired to fix problems and cover warranty. QVC has done a great job with this. I am sorry I do not have the number in front of me at the moment.
Oct 04, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Emerson Smartset Clock Radio Logo
379 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
