My Tricity Bendix CIW800 is currently leaking quite badly. It only leask when it is running (pours out of the bottom of the machine). I cleaned out the filter and found quite a lot of what looks like shredded white plastic in it... this has lead me to believe it is not a good sign. Any idea what this is and can it be repaired?
  • 50 Answers
Let the washer fill up. Look for water while it fills it mite be the fill hose Stop the cycle when it starts to ajatate. Let stand and look for water. If you see water your washer drum or the contaner that the drum sets in is cracked.Start washer and look for water while it ajatates this would be the cover around the top of the drum
Posted on Jul 12, 2009
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
I have mislaid my manual. i am trying to clean the filter of my tricity bendix 1000rmp washing machine. I opened the small door at the bottom right of the machine and unscrewed the cap inside . now the...
Make sure the filter and the housing are clean and that there is no grit or similar on the seal, if it still leaks, then you may have to fit a new filter and or seal.
Nov 05, 2010 | Tricity Bendix AW1000W Front Load Washer
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Solve Your
I have spent most of the afternoon looking for the float etc. In frustration I upended the machine to look for the inlet hose point, water started pouring out so I put the machine back in the upright position. Now it's filling with water and working again. Maybe there was something in the hose which became free with upending it. Not sure, but worth a try, it worked for me!
Mar 11, 2010 | Tricity Bendix 18 in. DH090 Free-standing...
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
Tricity Bendix
try opening the small front panel at the bottom right hand side of the machine unscrew the drain guard and check for any blockages
Sep 08, 2008 | Tricity Bendix AW1260W Front Load Washer
Brand new washer dryer leaking - Triciy WDR1241
Go back to dealer ,make sure it is plumed OK .close bye
Oct 08, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Open Questions:
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
