3 screen colors have separated and screen is bowed in the middle.
    Problem Solver:
  • 10 Answers
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Posted on Jul 12, 2009
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The words bow across the screen, the color is out of allignment
Hi my name is Roety,
I hope I can help you with your issue ,
Sounds like the closed captions are on, turn CC off or set to CC1
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 30, 2009 | Televison & Video
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors separate and the picture bows in the middle
Ur convergence is dead,buy convergence kit.U know how to solder?Tries these websites.Tv Repair World.com.
Sep 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Bowed in at top and bottom and colors are separated
You have a convergence issue. First question in customer menu under setup do you have the convergence optioin? IF you DO NOT then chances are you have the fl231 problem. check under my profile in the tips and trick section. IF you do have the option try autoconvergence. if this fails(goes red screen then you might have a convergence power supply problem.
Nov 04, 2008 | RCA D52W19 52" Rear Projection Television
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Panasonic PT 47WX51 TV troubleshooting
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Mar 25, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
