Question about ASUS (ASUDVDRWM6N) DVD-RW Burner
DRW-1814BLT compatibility with IDE hard drive
I have ASUS DRW-1814BLT dvd-rw, i have hard disk of 40GB seagate IDE interface. but my computer is not detecting it. is there any jumper configuartion for making this dvd-rw as master, slave or cable select, also please tell me that what configuartion i made for dvd-rw and ide hard drive that they work together. i have DG33FB with 2 GHZ dual core intel processor, 1GHZ ddr2
With A8M-VM series Mother Board the Asus DVD Writer Model No.DRW-1814BLT Lightscribe Not supporting.
Posted on Feb 04, 2008
  • 749 Answers
Put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Posted on Nov 15, 2007
My ASUS DRW 1814 BLT does not recognize the Lightscrib discs. I have windows 7 32 bits
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 14, 2011 | ASUS DRW-1814BLT DVD±RW Dual Layer Burner
My computer doesn't register the ne.ASUS DRW 24B1ST - Disk drive - DVD±RW (±R DL) / DVD-RAM - 24x24x12x - Serial ATA - internal - 5.25" - black I had a ATA before and have now got a sata. The...
goto device manager,,...Open the "Run" dialog box by pressing and holding the Windows key, then press the R key ("Run"). Type devmgmt.msc.when it opens,right click the topmost icon,,choose "scan for hardware changes"..
sometimes,windows not show your dvd drive,unless you put a disk in.
Sep 15, 2017 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Want to connect a new samsung hard disk to computer
There are two main types of interface for disk drives in personal computers. If you give us the model numbers from the drives we can tell you for sure.
The older style drives are called IDE. They normally have a flat ribbon cable with 40/80 wires. This is probably what the 40GB uses. If your 160GB drive uses a different interface it may be a SATA interface this uses a small plug with only 3 or 4 wires. These are used in modern desktops. You can't get an adapter to simply change from one to the other. But you may find that your CD/DVD Rom uses an IDE interface and you can share the cable with two devices (if so ask here for tips on sharing a cable). You may also find an unusd IDE port on your motherboard.
If there are no IDE (40pin) interfaces to be found you can get a add on interface card that will let you run ide devices. Common cards will go into a 32 bit PCI slot on your motherboard. You will need to make sure you have a spare slot of the right type before you buy an interface card. You can get these on ebay fairly cheaply.
I have made quite a few asumptions here. Post some more information about your motherboard and the the drives you have and we can confirm things for you.
Jul 21, 2009 | Computers & Internet
My DVD RW says some DVD-R's are CD-R's
make sure the disks are +- - + compatable to your burner
Jul 08, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
My DVD writer reads but does not write.
DVD discs have to be formatted before they can be recorded on.
Jan 02, 2018 | ASUS DRW-1814BL Internal DVD Drive
Does not read dvd
According to Asus there are many burned dvd formats that are not supported or simply do not work in this drive. Asus stated that most dvd-r should work but not all, and that is the only burned dvd media that works. You may want to look into buying a different drive.
Dec 17, 2008 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
Seagate ST3160215A 160GB Ultra ATA/100
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
Asus drw-1814blt
Hi there reinstall the driver is you have the disk if not download from there will be a small charge for download if not go onto your PC manufactures website and see if you can download from there.
Thanks J
Dec 05, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
224 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
