Question about Garden
I have a murray 4hp that runs 15 sec per prime then stalls.
I have a early 90's quantum power 4hp lawn mower. the last I used it it is was fine(1 wk earlier). I went to start it and it runs momentarily. If I keep pushing the primer I can keep it running. Seems like its not getting fuel to the engine. Replaced plug filter and primer bulb.
  • svkelly Jul 12, 2009
    I tried the carb cleaner with no results. I replaced the tube also since I ripped a hole in it taking it off. The carb is under the tank and yur probably right about removal. I'm guessing I will have to rebuild.
    Genius:
  • 1,114 Answers
First. try using Carb Cleaner from spray can to clean carb throat, and putting Carb Cleaner in fuel tank.
If this does not work-
Removal of Carb is probably needed. Sounds like Carb is clogged and needs to be cleaned.
If this is a Briggs engine and the Carb sits on top of the fuel tank, can be that the pick up tube from tank to carb is clogged.
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Quantum 4hp powerpro
you have a blocked primer passage take off filter huosing blow dirt out of passage and out of prmerball it might be bad enough to rebuild carb
Jul 05, 2014 | Garden
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
B&S Quantum Power 4hp won't start with fresh plug,
Did it run before you changed the plug?Gap is correct, flywheel shear pin may be bad, Water in the Gas?
Jul 02, 2011 | Poulan "" Push Mower
I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn mower engine shuts off after about 15 secs of starting.
Possible solutions:
-Water or trash (or both) is in the gas tank which means you must empty all gas from the tank and refill with fresh gas. The carb. will need to have all old gas removed too. If this is the case you will want to empty your gas can too because it may be the source of the water/trash.
-Replace the priming bulb.
Jul 29, 2009 | Garden
What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Jun 26, 2009 | Garden
Garden Logo
263 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
