marcello borreli Posted on Jul 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Teac Ag D9100 Receiver how to install a equalizer
Steve
Level 3:
  • Teac Master 3,290 Answers
  • Posted on Jul 25, 2015
Steve
Teac Master
Level 3:
Answers
3290
Questions
Helped
1127413
Points
12184
I'd connect it between the "Tape 2 Monitor" jacks. On the TEAC, the "Record" jacks are audio OUT and the "Play" jacks are audio IN.
Connect the Record to the EQ's IN and the Play to the EQ's OUT.
Select your source (AM, FM, Phono, CD, etc. and when you select Tape 2 Mon, you'll pass the signal to the EQ to shape the sound of the source. With it unselected, you'll bypass the EQ.
3 Related Answers
Anonymous
  • Posted on Sep 19, 2008
SOURCE: lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on May 08, 2009
SOURCE: TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
caroldon
  • 17130 Answers
  • Posted on Oct 27, 2011
SOURCE: I have a Teac Receiver AG-D9100, sound cuts off,
This can be related to a fault in the potentiometer as it cut off the tracking of the voltage and gets back to feed the digital circuit. You need to check, sometimes a switch cleaning oil can help.
Try to wriggle the pot control many times as it can help, if not replace.
Install a equalizer to Teac Ag D9100 Receiver
From what I can tell (from photos), you'd hook an equalizer in the Tape 1 or Tape 2 path, where the EQ takes its input from the receiver's Tape 1/2 output and the EQ feeds its output to the receiver's Tape 1/2 input. When you want to switch the EQ into the signal path, you just push the tape monitor button for whichever tape path you hooked up.
I have a Teac Ag D9100 Receiver how do you install a equalizer
Best way to hook up equalizer is see if receiver has preamp outputs that can be connected to amp inputs. If so hook up equalizer to them and you are in business. Or you can hook up equalizer to the output of the device you want equalized and then hook up the EQ output to any receiver input.
Teac d-9100
Check your speaker and speaker connections. Do you have normal display? If so, after checking your speaker and speaker connections and they are ok, you might have a problem with one of your output elements (Mosfet).
I have a Teac Receiver AG-D9100, sound cuts off, but if I touch the master volume knob it comes on for a short time. What to do? jmf
2answers
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
1helpful
I would like to run my TV sound out of my TEAC AG-D9100. Can I connect my TV sound output to the VCR/VIDEO4 input without a video input and then switch to VCR VIDEO4 to get the output sound? I have the...
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
1helpful
2answers
2answers
Lost manuel for teac ag d9100 reciever
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
