Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire Dishwwasher Won't Reset After Cycle
My Frigidaire dishwasher cycles through and cleans fine. When it is done drying, the drying light remains on and will not reset until I flip the breaker essentially cutting power to the machine. When I do this, the dishwasher is able to reset and I can use it again. I'm thinking it is probably the control panel...is this something that I can change out myself or do I need a pro?
  • 35 Answers
SOURCE: frigidaire gallery dishwasher fdb949gfb2
it looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
Posted on Jun 25, 2007
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
Posted on Jun 09, 2009
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
Stuck on washing cycle
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Nov 17, 2014 | Frigidaire Washing Machines
Dishwasher will not go thru full cycle
Hello friend, thank you for your post!
Based off the information you provided your Frigidaire dishwasher will not complete a full cycle. It sounds like it could be an issue with the control panel or door switch. When your dishwasher stops working does it display an error code or do a series of lights flash? I would recommend performing a reset on your appliance which can be done by disconnecting power from your dishwasher by either unplugging it or flipping the household circuit breaker. Hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire Dishwashers
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
My dishwasher does not go into the dry and clean cycle. It just stays in the wash cycle.
stwaterdog5,I am not sure what model it is but the heating element may be defective.Check to see if heating element is on right after it finishes draining.
Hope this helpsJoe Connolly
Nov 10, 2011 | Frigidaire Dishwashers
FRIGIDAIRE DISHWASHER CLEAN LIGHT FLASHING WILL NOT WASH OR DO ANYTHING
Do what 'mrrevo'l says to reset the dishwasher, and next time, try not to open the door during the wash cycle. Make sure that all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Jul 15, 2009 | Dishwashers
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Mar 20, 2008 | Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
67 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
