Question about Uniden Unipro PC100
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port 4 What is wrong?
    Novelist:
  • 142 Answers
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Posted on Jul 24, 2010
    Problem Solver:
I have the a similar problem. I'm surprised the HiPro shows up separately in Device Manager. Which serial to USB adapter do you have? Is a one port or two port?
Posted on Aug 05, 2009
Programming a TK-5320 using KPG-112DN V.2.20 keep getting "LOC" in display before the name of the channel.
Yes, radio. Check your cable. Is it OEM? Try plugging it into the radio before launching the software. Then try after launching the software. Is it a USB or Serial cable? If serial, the USB adapters often do not work. I have one brand of radio where I need to restart the computer each time I program so it will read the Serial to USB correctly. Even then, I may need to go into device manager and enable/disable it 2-5 times. I do not know if the software is the latest, but if a radio is programmed with the newest software, you cannot go back to an older version 90% of the time.
Aug 08, 2016 | Kenwood Radio Communications
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Need to change port number for the usb beljin adapter F5U109. Need to download driver software.
in the device manager click on (ports lpt com) double click on belkin usb adapter the properties will open then click advanced ant set the com port. you will find the driver here https://www2.belkin.com/support/product/?lid=en&pid=F5U109&scid=1
Jul 08, 2010 | Belkin USB/Serial Portable Adapter...
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Blekin USB/Serial adapter, MacBook Pro, and Garmin etrex GPS
According to a tech support person at Belkin, this device is compatible with OS8x and OS9x, so it is not going to work with OS10 unless new drivers are released.
The drivers available so far are listed here:
http://www.belkin.com/support/download.asp?lang=1&download=F5U409&mode=
Aug 24, 2009 | Belkin USB/Serial Portable Adapter...
I need a Vista driver for the USA-19QW Serial Adapter
I have an old 4-port Keyspan serial device that also doesn't work with Vista.  Unfortunately Keyspan didn't provide Vista drivers for some of the older USB to Serial devices before they were acquired by Tripp-Lite, so you will probably need to get a replacement (Keyspan usa-19hs has Vista support, that one works for me).  The support page for Keyspan USB devices is here: USB Connectivity & Device Servers
Apr 20, 2009 | Keyspan (USA-19QW) Serial Adapter
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
New Computer wont talk to machine
I had the same problem and it was never addressed by singer we finally figured out that singers software was not up to date with the new computer so i just sold my new computer and went with and older model I had Singer would not take responsibility for not having up to date software so good luck if anyone has a new computer
Jan 17, 2008 | Singer Quantum XL-6000 Computerized Sewing...
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Uniden Unipro PC100 Logo
2,318 people viewed this question
Top Uniden Computers & Internet Experts
Marvin
Marvin
mark
mark
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
