Question about Refrigerators
REFRIDGERATOR COMES ON BUT DOES NOT COOL AFTER MOVING IT FROM ONE PLACE TO ANOTHER
    Problem Solver:
  • 10 Answers
Why are you moving ur ice box around from one place to another?if its not cooling go to ur hardware store get u some coolant lil metal can and fill up ur coolant lines--in back of icebox--make sure be safe unplug it before doin anything
Posted on Jul 12, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
Frezer works both AC and Propane Refridgerator
move temp sensor inside see side move up to cool down to warm up if no change replace
Sep 01, 2013 | Dometic RM2620 Refrigerator
We have a 2 door LG refreidgerator.(2 years) We can see the freezer is cooling but nor cool air coming into the refridgerator compartment what would be the problem.
Hi!!
Check your temp. settings, Sometimes we move the controls by accident. Also check the fan in the freezer, make sure it is woriking properly, this fan is the one that blows cool air into fridge compartment.
Good Luck!!
Mar 13, 2010 | Frigidaire FRT21S6A Top Freezer...
My Dometic RM2652 RV Refridgerator is freezing on the bottom portion of the refriderator. I read that there is a recall for my refridgerator. Can you tell me what the problem is.
On the back of the refer are the cooling fins. There you will find a small piece about the size of a dime with a wire attached to each side 2 wires total. Move it down the cooling fin to about 1/2 inch from the bottom of the fins
This should solve your problem
Feb 01, 2010 | Dometic RM2652 Refrigerator
Moved working Kenmore refrigerator now it does not cool,
moved refridgerator now not working only light on??
Oct 07, 2009 | Kenmore Refrigerators
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
MY refrigerator is running but is not getting cold.
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
