Question about Refrigerators
Water drips from freezer into refrigerator
Water leaks from the air flow structure in the back of the refrigerator where it brings air from the freezer. It freezes on the top shelf and drips down the back of the refrigerator and collects in and under the vegetable bins. I vacuumed the refrigerator coils front and back. They were dusty. I checked the evaporator pan and it was dry and dusty and looked like it had not contained water in long time. I stuck a flexible drain cleaning brush up the drain hose but nothing appeared to be stuck in there. There is also a larger diameter tube nearby that seems to be associated with a strange vent/drain apparatus on the upper level of the bottom of the refrigerator, behind the crisper drawers.
  • hvddmiller Jul 18, 2009
    I will try to find the drain inside the freezer but I don't know how to remove the freezer wall. I'll try to tackle that one over the weekend and let you know how it turns out. Thanks for the advice bdenton1957.
    Sergeant:
  • 272 Answers
The drain is clogged..you need to see if it has a rubber drain trap going into the back side of refrigerator. if so, twist and turn as you pull it out and clean it..replace and then check that drain is open..if no drain trap on back side of refrig..remove freezer wall and open drain from inside freezer..you need to clean out drain trough using hot water..a little messy,but effective
Posted on Jul 12, 2009
My air condition is not cool. In mid west region with heat pump. The water condesation drip from the pipe but is not much. Does this need frion refill. Does this need one.
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
Hear liquid leaking in freezer
NO LEAKS showing water outside of unit ?? When a refrigerator goes into auto-defrost the unit shuts down the air-flow and coolant systems..in turn it turns on a heating element located in the freezer where the coils are..the heater melts frost build-up and the water drips onto the heater causing a slight popping or sizzling sound..MAYBE ?
Jan 04, 2018 | Kenmore Refrigerators
WHY IS THERE WATER LEAKING INSIDE THE REFRIGERATOR
generally water leaks on top mount freezer types when the defrost tube is plugged. The automatic defrost system works to keep humidity from blocking air flow across the evaporator(behind the back freezer panel) If it can not drain you will see it as water dripping from the top of the fridge section and water under the crispers.......Clean the drain tube under the evaporator of ice(poke a hole in evaporator and you are buying a fridge)........hope this helps
Jul 29, 2012 | KitchenAid Refrigerators
Water drips in bottom shelf of freezer, creating a piece of ice and then water leaks under refrigerator
The drain hole is blocked, so water is not drain and getting freezed, and then melting and it leaks.--------the drain is stopped up ,, remove the inside back panel inside the freezer and pour hot water into the troft under the coil in the back and flush the drain ,, once water runs though the drain hole then put the panel back in and it will be fine.
The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. You can take the sheet metal cover off the back, get a turkey baster and flexible tube, and continuously flush hot water.this will clear the clog.--------- Thanks.
Sep 13, 2011 | Frigidaire Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water dispenser drips how can I fix it?
There are two possibilities. The water control valve is leaking while off or the water has air bubbles in the supply line. If you just recently changed the water filter and the air has not been completely purged this will cause a drip until the air is out. You can also remove the water line at the control valve and see if it continues to flow. Just us care by unplugging refrigerator first. Be right back with part numbers, Sea Breeze
Dec 22, 2009 | Amana ABD2233DES Bottom Freezer...
My Jenn Air refrigerator ice maker is dripping water out of the front right side (one drop at at a time) into the ice tray. The water causes the tray to freeze up into big clumps. Any suggestions on what...
Unplug water control valve for the ice maker side on rear of freezer. If water continues to flow replace the water control valve If you already tried that the bring me up to date on just what you have tried and how long this has been happening. Sea Breeze
Oct 25, 2009 | Jenn-Air JCD2295HES Side by Side...
Water is leaking under my refrigerator
1)--In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. 2)--If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn?t out of place, broken or cracked.
Jun 12, 2009 | Whirlpool Refrigerators
Refrigerators Logo
572 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
