Question about Garmin nuvi 885T GPS Receiver
How to set interface option to garmin or host on my nuvi 885T?
4 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: garmin nuvi 885t voice command address does not
It seems that it's a software problem ,. To software problem on your device , you need to reset it .
To reset your NUVI , please follow one of these procedurs :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 20, 2010
mc1bean
  • 3053 Answers
SOURCE: I need to set th interface option to garmin or
Hello Debbie,
Maybe this will help you some. I have found you the complete manual which covers most of the models of the Garmin Nuvi. It is the full manual from start to finish with complete operating procedures as well as schematics, operation instructions complete with pictures, and trouble shooting section and even other contact numbers to deal direct with Garmin, if your model is not covered in this manual.
Here is the link for you:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Also if you can, please rate my solution if you can and some kind words would be appreciated. I also took the liberty to put my link at the bottom of this page that directs you to my personal page for all my areas of expertize, such as Automotive, Appliance, Electronics. Feel free to check it out anytime and save my link for future problem. Thanks So, Much Mike.
http://beta.fixya.com/users/mc1bean
Posted on Oct 25, 2011
bunnydawg
  • 5158 Answers
SOURCE: my name is karl how
you need a usb cable and if you go to www.garmin.com you can download the updater program (as well as the user manaul if you need it)
Robert
Please take a moment to rate this solution..thanks
Posted on Jan 31, 2009
How do i change the interface option to "host" or "Garmin
I ran into the same problem. I then searched many websites and found some good info at: http://forums.gpsreview.net/viewtopic.php?t=11571. But, in the end, I simply changed USB cabels and the thing worked. So try changing your USB cable first, then go to the above website if you are still having trouble.
May 06, 2010 | Garmin nuvi 885T GPS Receiver
Tip
How to Download your Garmin Nuvi 885T Users Guide
Have you lost your User's Manual for your Garmin Nuvi 885T?
Would you like a digital copy for easy searching of terms and quick reference?
The Garmin Nuvi 885T owner's manual is available here.
I hope that helps.
___________________________________
Garmin Nuvi 885T Firmware Download
Garmin Nuvi 885T Hard Reset here
Change Nuvi 885T Language
on Jan 31, 2010 | Garmin nuvi 885T GPS Receiver
Tip
How to Change the Language Setting of your Garmin Nuvi 885T
Does your Garmin Nuvi 885T display the wrong language?
Would you like help resetting your Garmin Nuvi 885T default language?
To change the language settings of your Garmin Nuvi 885T touch the following icons:
  1. Tools
  2. Setting
  3. Language
Then select your preferred language from the list.
'Tools' is the wrench in the bottom right corner, labeled '9'.
'Settings' is the wrench in the top left corner.
'Language' is the mouth in the bottom right corner.
I hope that helps.
For more Garmin Nuvi 885T help, see my other Nuvi 885T Tips: Hard Reset and Unfreeze and Download Nuvi 885T Manual.
on Jan 25, 2010 | Garmin nuvi 885T GPS Receiver
How do i change the language on an 885t garmin. I
Here are the directions to resetting the Garmin Nuvi 885T language settings.
  1. Tools
  2. Setting
  3. Language
I hope that helps.
For more Garmin Nuvi 885T help, see my other Nuvi 885T Tips: Hard Reset and Unfreeze.
Jan 22, 2010 | Garmin nuvi 885T GPS Receiver
How to change the language on the home screen of the nuvi 885t to English?
This is a Fixya Tip to reset the Garmin Nuvi 885T language settings.
  1. Tools
  2. Setting
  3. Language
I hope that helps.
Jan 11, 2010 | Garmin nuvi 885T GPS Receiver
Tip
How to Perform a Hard Reset of your Garmin Nuvi 885T
Does your Garmin Nuvi 885T Freeze at Loading Maps?
Does it lock up or stop working?
There are two solutions to this problem; sometimes either one fixes all problematic symptoms and sometimes they need to be used in tandem.
My previous Garmin Nuvi 885T tip explained how to install new software into the device and where to get the software from. This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 885T.
I hope that helps.
_____________________________________
on Jan 01, 2010 | Garmin nuvi 885T GPS Receiver
Tip
How to Unfreeze or Fix your Problematic Garmin Nuvi 885T GPS
Does your Garmin Nuvi 885T stop or freeze up?
Is the touchscreen unresponsive or stopped working?
As with most magic devices around us nowadays, there is a brain inside these units called 'firmware'. Over time, for whatever reason they become confused and stop operating the way they did when new.
The solution for these problems is to replace its internal instructions with new ones, called 'reflashing the firmware'.
This is an easy, automated process made simple by downloading and running some software from the Garmin website. A discontinued product, you can still find it here.
Download their software, and then run the file. You will see this screen (except it says 4.70 now):
Click the NEXT button and you are almost done.
Follow the prompts and soon your NUVI 885T will have all new software and should be running smoothly again.
Now that you have upgraded the software of your unit, you might consider performing a hard reset of the device. Please see my second tip for the Garmin Nuvi 885T for step-by-step instructions on how to do this.
I hope that helps.
The screen on my garmin nuvi 885t freezes? it was working perfect before? any idea
There are two solutions to get your Garmin Nuvi 885T running smoothly again. I have posted detailed directions in the Tips section of this Fixya website. Follow these two links to find step by step instructions on how to perform both the hard reset and the software upgrade.
I hope that helps.
Dec 21, 2009 | Garmin nuvi 885T GPS Receiver
Garmin Webupdater not finding internet connection
I recommend upgrading the system software of your Nuvi 885T GPS to the latest firmware. This link will give you instructions and locations of the files you need to update your Nuvi 885T GPS without using Garmin Webupdater.
Oct 06, 2009 | Garmin nuvi 885T GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
9,175 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
