Question about GE PTS22SCS Top Freezer Refrigerator
How do I set the fridge and freezer temps to their reccomended settings
    Sergeant:
  • 272 Answers
Usually they are mid-point of the highest value..like 1-6 and 3 would be normal or a-k and g would be normal and so on..
Posted on Jul 12, 2009
I would like to know the correct setting for the fridge and freezer
Setting? Most fridge/freezers have a crude system of setting the temp. and this seems to be dependent upon ambient. For a few pennies they could set the temp. accurately. However, but most peeps just turn it up/down until it's "about right"
The temp. for your freezer will depend upon the length of time that you wish to keep things. Check out freezer stars online. However they tend to have pre-set temp.
For the fridge, this will depend upon what you want to keep in it. but usually 4C is pretty good. You need to get a thermometer, put it in a glass of water (this irons out fluctuations). And check it after an hour. Adjust a little and check again. Repeat until happy.
Note that a cold room can prevent a fridge operating, so be aware of this.
Oct 28, 2017 | Refrigerators
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge too cold
The temp sensor or the thermostat is bad.
It is reccomended that the sensor be replaced whenever a T-stat is replaced.
You can purchace both for less than 50 bucks with most models at your local appliance parts warehouse.
(The T-stat is the part that you turn up or down to adjust temp and the sensor is the wire coming off of it to a remote location in the fridge. With some models it is all one part, with others the sensor can be removed seperatly.)
Dec 30, 2008 | Refrigerators
GE PTS22SCS Top Freezer Refrigerator Logo
49 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
