Question about Kenmore Ovens
My Kenmore Continuous Cleaning oven is older - it is running, or not running on a 50 amp circuit breaker. I can cook on the stove top, but the oven will only stay going for about 5 minutes before it trips the breaker - is the breaker the wrong size or? I just moved into this house, so I'm not sure.
If you are tripping a 50 A breaker, you have major problems. First check the breaker, to make sure it is in reality, tripping at 50 amps. As they get older they can suffer heat damage, and will trip at lower currents. How old is it? Does it visibly look like bad (burnt, etc) Is it loose on the mounting buss? Burnt smell? If everything checks out then go to the oven and look for loose connections. There will be heat where there is a 50 amp current draw. If the oven is suspect, I would seriously consider dumping it as soon as possible. This is serious fire safety hazard. Again, loose connections. Check all of them, both AC+ legs, Neutral, and ground.
KF Groves
Posted on Jul 18, 2009
Model MET8775XS00; oven temp control not working properly. Lower oven take too long to heat up & temp calibration per manual does not work. Temp control is very erratic. Suggestions?
What is the age factor on the stove? You may want to get someone to come in and check it out, as it puts out some very high current. Stoves run on 220--240 volts, and the oven jacks up the Amps, which is a hazard if you make contact on them.
You can get a voltmeter and test the wall outlet for the power being put out. Sometimes if the wiring in the house has a bad line, it can't get enough to work.
Also, if you have a breaker box, you can test it to see if it has a dual electrical breaker for the 220-240 line.
If the stove is getting the proper power supply, then it could need fuses/breakers in the stove itself. How does the cooking plates on top work? The oven may have some elements that need replaced, but it may be cheaper to purchase another stove.
Dec 04, 2017 | Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 23, 2010 | Kenmore Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Kenmore Ovens
Eyes work but the oven or broiler does not
Check your breaker panel and see if any breakers are popped. Stove breaker is around 50 amps.
Jun 30, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Stove has locked down /frozen
turn off the circut breaker for the stove. I JUST had to do this myself.
Jan 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
465 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
