Question about Car Audio & Video
I cant tell what wires in the hyundai excel to connect my new sony stereo to can you help?
    Genius:
  • 1,114 Answers
If you purchased your new stereo out-of -the -box factory fresh, then it should have a plug set which plugs into the back of the new stereo. If your old car stereo plug is still connected to the all the wires(that is the plug that the car radio plugs into), then -
The easy way to hook up new stereo to old connector is buy an adapter plug that will match the old plug with the new plug. You will have to connect the wires from the new plug to the old plug ,but that is easy because both plugs have the same color wires.
Go to ' installer .com' and you should be able to find the right plug. Hope this helps...
Posted on Jul 12, 2009
2005 Hyundai Accent changing out Hyundai Radio for a Pioneer MVH-295BT The wiring colour code of the Hyundai is not compatible to that of the Pioneer radio.
Not sure where you are but Repco sell conversion harnesses that suit a lot of different cars. I used one of these to put a new stereo into my Sons car and it worked perfectly. It matched up the Hyundai radio plug to the new Stereo. Cant remember which make of stereo. Give Repco a call. I think it was about $25 and saved a lot of grief.
Oct 26, 2018 | Pioneer Car Audio & Video
What is the pink wire for in the stereo of a 2006 Hyundai Santa fe? and what do I connect the dimmer wirefrom the santa fe to in a new stereo
The pink wire from the stereo unit is often the dimmer wire, and is connected to a power feed from the vehicle's side lights. Not all stereos have a dimmer function however, and may not have this wire available.
Nov 04, 2012 | 2006 Hyundai Santa Fe
Hyundai excel wiring diagram
are you talking about the radio if so here it is
Car Radio Battery Constant 12v+ Wire: Red/Yellow
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Brown/Green
Right Rear Speaker Negative Wire (-): Black/Green
Jul 26, 2010 | 1994 Hyundai Excel
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
Jul 12, 2010 | 1990 Toyota Corolla
I have a 2004 Hyundai Elantra and am trying to install a stereo but dont know what the wiring diagram is..any help?
Personally owning this car and installing several Hyundai stereo's, I would purchase a wiring harness kit from car audio shop or electronics retailer. The wire harness has a plug that connects to the cars wiring harness. This wiring harness kit will also list the wires to connect your new aftermarket radio to the harness. I would also recommend using crimped **** connectors to attach the two harnesses together.
Feb 24, 2010 | 2004 Hyundai Elantra
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
What are the wire colors for the stereo
Oct 01, 2009 | 1990 Hyundai Excel
Hyundai excel braking squeek when steering.
This is Caused by Worn Brake Pads. Get some new Pads Installed and it will fix this Problem for you. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 30, 2009 | 1994 Hyundai Excel
Truoble programing radio stations.
it sounds like the memory wire isnt connected to the correct position the memory wire on the stereo needs to go to b+ also a faulty battery can cause this even if the battery can still start the car. an auto electrician should be able to test the battery for free to eliminate that as the problem
Jul 02, 2008 | 1992 Hyundai Excel
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
