Question about E-Machines eMachines Desktop PC
Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Sounds to me like the pc may not be able to recognize the RAM your trying t put into it. Whats the model of your PC?
  • Jared Grant May 11, 2010
    What's the model number of the pc?
  • E-Machines Master
  • 5,660 Answers
No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
(BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
Things to know about the older Sdram ram memory.
1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
Point? All ram from SDR to DDR3, IS Sdram.
2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
This means you need THE ram memory for YOUR eMachines computer.
Main factors when buying SDR Sdram,
A.Correct type. You know this. SDR Sdram.
168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
Posted on Jul 13, 2009
  • E-Machines Master
  • 4,924 Answers
First ...make sure your pc supports this kinda Ram ...then get into bios and take a look cause at some elder pc specialy that runs on ddr not ddr2...there is a settings which will allow to read both module ...
the thing you might also do ...is to remove the bios battery to restore any old settings ...I did have a problem like this when I swiched a machine from ddr2 on ddr ...and it just didnt want to boot...after you put it right ...reinstall the operating system to get all your features to see the new phisical memory ..
Posted on Jul 12, 2009
  • 22 Answers
The type of RAM on eMachines T6410 takes is 184 Pin DIMM DDR PC3200. The maximum amount it will hold is 2048MB (2GB).
    Brigadier General:
  • 4,088 Answers
Get into "setup" which shows up when starting computer. The screen that shows the hard drive setup should also show the installed memory. If not, does the machine support the new memory? Check owners manual. Only very old machines required switch settings to reflect installed memory.
Yes, if you provide the make and model we can help you with this.
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
I need to upgrade the ram in my Ms-6312 ver1 motherboard i need to know what the best ram and what will work i need atleast 2 gb
I have the same board. You can only install 256MB of PC100 RAM in each slot, for a total of 512MB. PC133 RAM will work as well, but it will run at PC100 speed.
Feb 25, 2010 | Gateway MS-6312 (4000785) Motherboard
DELL Optilex GX110 - RAM
Put the "old" RAM back into the computer, to see if the PC will work at all, or if you damaged the motherboard when you were changing the RAM, or if you accidentally disconnected some cables or jumper-blocks.
Feb 03, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Upgrading my 128 RAM of KOB 810e FST MB
Looking at the manual for this motherboard your maximum ram is 512mb in two sticks of 256mb each. Speed rating is pc133 (maximum). You may struggle with the external hard drive as you only seem to have usb 1.1 and not usb 2.0
Jun 05, 2009 | Computers & Internet
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Memory upgrade
Dell dimension 4100's only support a maximum of 512MB ram.
2 - 256MB PC133 SDRAM modules - 1 in each slot
Nov 20, 2008 | Dell Motherboard Dimension 4100 Intel 815...
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
E-Machines eMachines Desktop PC Logo
223 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
