Question about Refrigerators
Water is not flowing to ice maker. - Refrigerators
    Sergeant:
  • 272 Answers
This is the first step..make sure the tube that allows water to flow into your icemaker is not frozen up. if it is, derfrost and replace water valve. if not, make sure you have water going to refrigerator..second step..does your icemaker come on? you can actually start these by using a jumper wire on some models and not knowing your style. i'll just suggest, wait and see if it starts by adding about 4 ounces of water into your mold. see if it pops the cubes out. make sure its turned on..as long as its cold enough in the freezer . It should start up . If not dumping ice in say four hours. you may need a new I/m assembly..if it does, and does not fill on its own. replace fill valve...Bruce
Posted on Jul 12, 2009
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Ice maker will not work. No water flows into ice maker. What is cost of replacing ice maker? Ice maker is part no. 628370.
If the problem is only that you don't have any flow of water in ice maker then you should check the water solenoid, the water filter if its cogged or water container if it is frozen,
In any case the Ice maker is abot $140
Nov 05, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
I can get water out of door but water is not filling ice cube tray.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If you get water the ice maker is the problem.
Jul 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 06, 2009 | Refrigerators
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
