Question about Garden
What should the compressin be on a briggs
My 19hp B &S lawn mower engine is blowing burning white/blue smoke. I checked oil breather and it seems to be ok. I bought a compression test kit and I am getting a dry reading of 60. Is this normal. Engine runs but I would like to know if I should replace rings. And should I also hone the cylinder? And what should the compression be?
    Top Expert:
  • 10,875 Answers
What is the compression ratio for my engine?
Briggs & Stratton side valve (L-Head) engines use a compression ratio of 6 to 1.Our Overhead Valve (OHV) engines use a compression ratio of 8.5 to 1.
What would cause my engine to "puff" smoke while it runs?
White/blue smoking usually indicates the burning of oil. Causes to this condition include:
  • Overfilling the crankcase with oil
  • Incorrect oil grade
  • Operating engine at greater than a 15 degree angle
  • Inoperative crankcase breather
  • Crankcase air leak
  • Blown head gasket
  • Worn cylinder and/or rings
  • Turning/Tilting the engine on its side for any reason (storage, changing oil, etc). If the engine has to be tilted, ensure the spark plug is facing upwards to help prevent oil from escaping the crankcase.
Also, be aware that any small air leak can cause an excess of air entering the crankcase and will create a higher oil mist than the breather is capable of handling. The excess oil will then return through the breather tube and back to the air filter. Engine oil capacity is dependant on your specific engine model. To determine your engine's oil capacity, please visit our Oil Capacitypage. Oil level checking and changing intervals are available on ourMaintenance Schedule page, as well as a hyperlink (text highlighted in blue) leading to oil changing procedures.
The "Oil" section of your Operator's Manual also contains this information. Other possible causes include operating or tilting the unit at an angle, an obstruction in the breather tube (located behind the air filter), damage to the cylinder/piston rings, etc.
Posted on Jul 23, 2015
  • John Goggin Jul 23, 2015
    Thanks Johnny Rebel,
    Just took off head and cleans valves,they were pretty carbonized, cleaned out breather tube. Lots of crap where tube attaches to carb.
    I can move the piston very slightly when it is In cylinder.
    So when I put the compression tester into spark plug hole I only got a dry reading of 60. Isn't this very low. I think I should be over 100.
    Is this why I may need new rings. Ps. The cylinder is in nice shape no scratches or scrapes.
    Thanks for your help,
    John
  •  johnny rebel
    johnny rebel Jul 23, 2015
    yeah do rings while you are there
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
Have oil spitting out of carb and dip stick fill tube just started doing that on 19 hp kohler courage
if engine is not overfull you have bad rings on piston have to take in to have it done may end up short blocking it witch is cheaper to do replace rings cheaper by far 200.00 per cylinder
Sep 14, 2014 | Garden
What is causing my kawsaki 580v to smoke
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
May 16, 2014 | Kawasaki Engines NEW 19 HP KAWASAKI ENGINE...
When you start engine white smoke pours out and oil is blowing out 2 feet out of muffler.
Hi michelley636
Check your oil level, it sounds like it is too much oil in the crankcase causing it to burn in the combustion chamber
Bud
Apr 29, 2013 | Briggs & Stratton Garden
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Smoke from exhaust when running lawnmower.
what colour is smoke? grey blue or black?....if its grey blue mower burning oil either motor is worn out or valve cover breather box failed...if smoke black carby sending too much fuel to engine
Aug 12, 2010 | Briggs & Stratton Garden
I have a briggs and stratton ride on lawn mower 14hp model 287707. engine pumping oil through breather into carburettor when running, its working but burning oil.
The float is getting stuck open which will cause the engine/sump to fill with oil and thats why you see oil comming out carby/air filter clean ya plug drain your sump turn motor over with plug out a few time to clean out check float/needle and seat in carby refil oil clean ya spark plug and off you go it will blow heaps of white smoke don't worry it is just buring th oil out if the exhaust/engine hope this helps some one
Mar 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Blue/white smoke from muffler, but when muffler is removed smoke disappears
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
Aug 03, 2009 | Briggs & Stratton Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
