Question about Kodak Cameras
I have a c310 camera and i need a new memory card, can i use a 2gb card or do i have to use a 1gb card?
    Scholar:
  • 119 Answers
The c310 (2007+) is compatible with SD and SDHC cards.
The SD is up to 2gb
The SDHC is up to 8gb
So.. you should be very safe with a 2gb card!
Posted on Jul 12, 2009
What type of memory card do i use for kodak easy share c310 camera
The C310 works with MMC and SD cards. MMC cards are nearly obsolete and hard to find, so I suggest SD cards. Be sure you get an SD card, 2GB and smaller. Larger cards are actually SDHC cards and will not work in the C310.
Aug 22, 2011 | Kodak Cameras
What GB memory card does work in a C310 digital camera. My printer dock does not work anymore except to charge my camera and I thought I could get a memory card and print the few pictures I take at a...
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
BTW, FixYa doesn't have an online store.
Jun 21, 2011 | Kodak EasyShare C310 Digital Camera
What am I going to do? the SD card could not be format in Kodak Easy Share C310 camera?
The Kodak will only format memory card under 1gb in size, for some reason it wont work on bigger cards
Mar 02, 2011 | Kodak EasyShare C310 Digital Camera
A new SD card 2 GB wil not work in my C310 kodak digital camera Message in camera "memory card full" message in card reader when trying to format the card says "write protected" Is this card too Big?
No, the C310 will handle a 2GB card.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 10, 2010 | Kodak EasyShare C310 Digital Camera
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Jun 07, 2010 | Kodak EasyShare C310 Digital Camera
I have a kodak c310, trying to format the card and it keeps saying memory full format card, so i format and it comes up FILESYS ERROR e00100, but it's a new card?
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Oct 21, 2009 | Kodak EasyShare C310 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Kodak EasyShare C310 Digital Camera
2 gb sd card
Hey Guys yes I am from South Africa Just bought the SD 2 GB ScanDisk sd card - Same Thing
Pathetic to say the least!
Anyways - Thanx for the comments what i have learned from this is that its not just ME with the problem, and I must say I feel better!
Kodak C310... well you cant compare it with the big boys...
Cheers
Stan
Ps: formatting the card in your pc does not fix the problem with the camera, I tried it.. The card works fine on my Garmin
Jun 05, 2008 | Kodak EasyShare C310 Digital Camera
Cameras Logo
35 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
