Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
I'm almost finished removing a Moen single handle (w/ sprayer) kitchen faucet. The middle (faucet) hole is giving me problems. I cannot remove the hose that connects to the sprayer. There is something that looks like a nut, but it is must be rounded off. I can loosen the not that keeps the faucet in tact, but cannot loosen the nut that lets the hose come off. Help?
  • 20 Answers
Turn it the opposite way. They are made to go on just the opposite of what you think you would do to turn them
Posted on Jul 12, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen kitchen faucet 87440 single handle model
    remove stem, turn it half a turn in either direction (180deg.) replace stem and your good to go
    Dec 01, 2012 | Moen 87440 Single Handle Kitchen Faucet...
    Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
    Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
    http://www.moen.com/shared/pdf/ca87530pt.pdf
    Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
    I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
    I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
    Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    We have a Moen 87315C kitchen faucet and it is dripping from the sprayer portion of the faucet, what's the problem?
    If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
    Apr 12, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
    Replace cartridge in Moen kitchen faucet and now
    it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
    517 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
