Kitchen Ranges Logo
Virginia West Posted on Jul 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan on my Sharp R930AK won't stop after broiling.
Claude Kayser
Level 3:
Top Expert:
  • Sharp Master 9,098 Answers
  • Posted on Jul 23, 2015
Claude Kayser
Sharp Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063327
Points
28436
Due to the temperature or a failing sensor?
1helpful
1helpful
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
I have a Sharp Carousel convection microwave, model#R930AK-F. Built in NOV< 2005. The fan runs, the tray will not rotate, and it does not heat food.
microwave's have fuses in them. try and replaceing them before you call the repair man.check on the web. for locations of fuses,hope this helps
Microwave, convection R930AK turntable will not turn and microwave will not cook. inside light works
That would be a defective secondary (lower) door switch or possibly the door switch mount is loose or misaligned.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Blown fuse
These items are not expensive
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757868&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757867&PPStack=1
Insert your model ( sharp R930AK ) at search tab of link below and select "thermostat/Thermal fuse " at PART TYPE to see parts availability
1helpful
Sharp R930AK
Control board has stuck relay or triac ( electronic equivalent of a relay) . Replace control board.
1helpful
Microwave convection heat shuts down
That could be several things, but to me the most likely is that your thermistor is caked with grease - somewhat shorted as opposed to open. By contrast, when the thermistor is open, the classic symptom is that the coolling fan runs more than it should. The other most likely possibilities include the damper motor or switch or control panel. You should be able to get any needed parts at Tritronics at http://www.wehaveparts.com You can find critical safety & disassembly info in the serice manual or at our Web site. We have the actual service manual for that model on our site at http://www.microwavedisplay.com/R930AKAW.pdf (if that URL fails try http://207.234.249.73/mwd/R930AKAW.pdf) Post back if you wish.
Top Sharp Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
