Question about Samsung LN-S4051D 40 in. LCD Television
Sound will not raise
When raising the sound it does not go very loud. We notice then when watching a DVD, not the sound watching just cable is not very loud with the volume at the max.
Try put new sound card tht suite with your pc and also get realtex mixer or nvidia etc. it will boost-up your sound
Posted on Jul 12, 2009
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help ยท Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
What could be causing a loud popping when volume is raised past a certain point?
This is normally cuased when customers rely on small amp in any radio instead of an aftermarket amp. If your radio starts to clip wither lower to normal listening volume or invest in a aftermarket amp to amplify sound.
May 19, 2014 | JVC KD-G230 CD Player
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
The system will shut off once the volume reaches a certain level. The system will not get really loud.
CHECK ALL YOUR SPEAKER CABLES YOU MAY HAVE A PINCHED OR PUNTCHURED SPEAKER CABLE. IF ALL YOUR WIRES ARE RAN ALREADY GO INTO SPEAKER SETTING GO TO SPEAKER CONF, WITH RADIO PLAYING, AND START RAISING Hz IF ITS A SPEAKER CABLE PROBLEM IT SHOULD CUT OFF WHEN UR RAISING THAT SPEAKER Hz. IF IT CUTS OFF WHILE RAISING THE Hz TAKE ONE SPEAKER CABLE STRAIT FROM RECIEVER TO THAT SPEAKER THEN TRY RAISING IT AGAIN. GOOD LUCK
Jan 09, 2011 | Onkyo TX-SR608 Receiver
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Dec 17, 2007 | Sony STR-DE475 Receiver
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Samsung LN-S4051D 40 in. LCD Television Logo
75 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
