It has a light indicating the power works but it stays blank
Switch it on directly from the TV. Try changing channels. If the screen stays black, open the casing and find a push-button switch near the tube or in the panel. It will reset it. If you don't, have it serviced from a certified tech.
Where do I find the casing?
The casing is what holds what's inside the tv.
Thanks, I got it sorted, it was the scart lead
Electrolytic capacitors you have to take the cover off the power supply to get to them. 3 of them will be 1000 uf @ 16v and the other 3 will be 1000 uf @ 35v the tops of them will probaly be bulged up replace those and that should solve your problem. you can replace all 6 with 1000 uf @35v and get them at radio shack for $1.79 each.
