Sokkia Surveyors Umbrellas Vinyl 8136-41 Logo
G
George brechin Posted on Jul 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What battery charger fits these rechargable batterys
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Jul 22, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1198154
Points
47629
Actually I don't know what kind of batteries uses your Sokkia Surveyors Umbrellas Vinyl 8136-41 so please specify the rechargable battery it uses. Probably it is specified in it's user's manual
I would like to buy (2) Rechargable ET18V-20B batteries that will fit my TURNADO ET-2506 portable chainsaw. Your help would be appreciated ! Phillip Silva
I honestly think you'd be better off replacing the chainsaw than trying to find batteries for it.
But, All Battery com Rechargeable Batteries Chargers can sell you materials to rebuild your dead ones, rebuild them for you or they might even have a generic in stock that will fit. I've recommended them in the past for some rather esoteric battery needs and they've always come through.
I have a pair that takes batteries an a charger base charger how does this work
They are often fitted with rechargable AAA cells. These can be charged by putting the phone on the charger base. Obviously the base must be plugged into power. You could alternatively take the rechargable cells out and charge them in a standard charger. The radios will also work with non-rechargable batteries but don't try and charge them or use the charging base.
4helpful
2answers
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
1helpful
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
2answers
How to recharge battery? Where does it plug into
It is under the little rubber cover, take it out of the way.
Wondering if this camera recharges batteries
once they are rechargeable batteries you can just check before you do it each time to make sure no one has put in normal batterys as it will have a bad result
3answers
Problem with wii fit rechargeable battery pack
make sure the battery charger is connected, and that the port connections are tight, other than that I would say you have a faulty charger.
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Top Sokkia Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Sokkia Measuring Tool and Sensor Expert? Answer questions, earn points and help others
