Question about RCA L42FHD37 42 in. LCD HDTV
Cant get to 1080i on rca 42" television - RCA L42FHD37 42 in. LCD HDTV
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Hdmi ports are not working
That HD mode.That good what else do u want.Unplug,replug the tv an hour later,might get HDMI ports work again.Not,ur Tuner board is dead.
Apr 26, 2010 | JVC LT-42X688 42 in. LCD HDTV
Is it a 1080 for hdtv
1080i or 1080p are both HD. the i and the p stand for the way the images are displayed. 1080i is interlaced, and 1080p is progressive scan. 1080p is the best hands down for fast moving sports and things like that, but for just watching your basic night time lineup, 1080i is fine.
Apr 25, 2010 | RCA HD52W59 HDTV Projection Television
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Sharp aquos 1080i is showing up at 480i. How do I
I have the same problem I'm sending 1080i to the screen and it will only display 480i. I too would love an answer to this question.
Jul 18, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Other inputs not working on rear projection toshiba
check for progressive scan and interlaced setting also verify if you have component hook up that it auto maticall chooses your resolution because if your tv is waiting for 1080i and you send 1080p it will not always work and if it expects 1080i and you send it 480i(s-video or rca connection) it may not automatically flip
Apr 14, 2009 | Toshiba 42H81 42" Rear Projection...
Getting a border around my picture
go to settings and change the resolution to 1080i or 720i
Feb 19, 2009 | Toshiba 42HL167 42 in. LCD Television
XBR450 32" - getting 1080i picture from upscanning DVD Player
You need 5 RCA cable wire (Red,Green,Blue+Red,White) comb RCA/Cable cords to flow back on the TV connector or review Manul books
Dec 13, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Upgrade Possible?
you will need to contact RCA helpline for the procedure
Jul 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L42FHD37 42 in. LCD HDTV Logo
89 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
