Cleaned under gauge console that is mounted on my fuel tank and when I reattached the odometer the numbers are barely visible. What is the problem?
SOURCE: oil capacity of engine crankcase on 2007 Honda VTX 1800 C
The factory fill is 4.3 litres. Thats new empty lines...etc.
3.75 to 3.9 quarts is a normal drain.
Heres a link for the complete service manual on the VTX 1800C
It's a big download about 50MB in PDF format
Hope this helps...ride safe and ride smart.
SOURCE: HOw do I check and replace coolant on a honda vtx
Try this forum. They can help you out.
http://www.vtxcafe.com/showthread.php?p=355760#
SOURCE: My Honda VTX stalled at about 60 mph. I thought
I would run a can of Techron fuel system cleaner through it. May have sucked some debris out of the tank and into the carb (injector). Also if it has a fuel filter I think I would change it.
Bob
SOURCE: I just bought a 2006 Honda VTX 1800, where can I
Go here and hit the download button.
http://printer1.blogspot.com/2009/07/honda-vtx-1800-service-manual.html
SOURCE: Where is radiator fill cap on my 2007 honda 1800
Hi, follow the top radiator hose from the rad it will then connect to the thermostat housing the radiator cap is located on the housing, if the rad is full you could simply top up your resovoir with coolant( do not remove cap untill the engine is cold)
