Question about Nintendo DS Lite Console
Ds lite wont turn on, no lights internal fuses ok. Got 4 volts at pin 1 of power switch, then dont know what should happen next when the power switch is turned on as pins 2,3,4,are common and pin 1 being live, does it temporarly send 4 volts to ground to turn something on, like it does in a pc power button. Also charging connector on the board has the pin that goes to the fuse is flattend and is going green inside the connector could this be grounding it.
  • 88 Answers
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Nintedo Ds Wont turn on! Even if Charged!
Does the yellow light come on when charging? Could be that the fuse for the charging circuit has gone, or on of the screens has been damaged. If it's only 4 months old and not been dropped etc, send it back to Nintendo I'd have thought.
May 24, 2010 | Nintendo DS Lite Console
Why wont my ds lite wont turn on
buy a new battery or recharge it
1 unscrew the screw on the back and take it out and replace it
Feb 10, 2010 | Nintendo DS Lite Console
Nintendo DS Lite not turning on
no there isnt a reset routine. have you tried the fuses.
do any of the screens flash when the green light flashes.
Jul 12, 2009 | Nintendo DS Lite Console
1996 hd 1200 xlh blinker wont work
I'd guess I would say,next check for 12 volts at pin 7 withe left turn button depressed and you say it worked,right? No? Check flasher unit for left side.Is your speedo doing strange things to?Check alarm system.Don't know why but anti-theft feature messes with left turn signal and speedo function.Disconnect neg. wire at battery,then reconnect and reset the alarm in usual way for when it goes off.[will go off when neg is reconnected].
Feb 14, 2009 | 2003 Harley Davidson FLSTFI Fat Boy
Nds lite wont turn on
There maybe something wrong with the jack inside your Nintendo DS, you can easily get them repaired at a few shops, just tell them that the On/Off switch doesn't turn the DS on and they'll fix it for you, shouldn't cost an awful lot as they're just replacing something inside.
Oct 10, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
New Lamp turning off after 5 seconds
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ds lite console keeps switching of then won't start again
Theres an internal error you will need to get it sent off for repair
Apr 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
310 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
