Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
I HAVE AO SMITH MOTOR BL6414 WHITE WIRE BLACK WIRE BLUE WIRE RED WIRE, HOW DO I WIRER THE CAPACITOR
    President:
  • AO Smith Master
  • 1,378 Answers
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
I have an A.O Smith SE2F01 115/220v Type C electric motor, it has 4 wires: White/Black/Blue/Red, I want to know which is which? And Does it need a capasitor?
Wiring diagram appears on side of unit.
With wire colors.
Capacitor: each electric motor has a run-winding and a start-winding with capacitor.
Both windings receive power.
The start-winding gets a surge of power from the capacitor > and this starts the motor.
The run-winding brings motor up to full speed.
Copy following link for motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 19, 2013 | AO Smith Pool & Spa
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
I am replacing my old a/c fan motor with a new one. The old motor is an A.O Smith B13400-251 and has black, brown, and a purple wire and was connected to a dual capacitor. The new motor is an A.O Smith...
For one, thank you for posting all the info, it really helps! On your new motor, the white has became your purple, black is black, and your brown/brown and white wires go to each side of the new capacitor, there should only be 2 terminals. You can leave the "Fan" terminal blank on the old capacitor now. Just be sure to attach the new capacitor somewhere secure, they are smaller, but can be a pain. So just to recap:
Black is still black.
White is what purple used to be (Com)
Brown on 1 side of new capacitor
Brown/White on opposite side of new capacitor.
Hope this helps get you to cooler days!
Jun 29, 2012 | Heating & Cooling
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is...
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Aug 25, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
What do wire colors mean for ao smith dl1056 blower motor
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
909 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Ian Summerfield
Ian Summerfield
Mike Raino
Level 1 Expert
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
