Question about Saniflo Sanibest macerator with multiple connections
Can a saniflo 003 toilet be installed with only the 005 tank, or does it need a macerator?
  • 297 Answers
Depends on how you use the unit. the macerator chews up paper and other unmentionables.I would suggest you use it as one unit.
Posted on Jul 22, 2009
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
I cannot get the top w/ gasket back on a sanibest after servicing the macerator
Make sure the gasket and it's grooved channel are clean also the inside lid lip where the gasket sits on should also be cleaned. Once all parts are cleaned properly install gasket to inside lid lip make sure it seats to the very bottom of the gasket. If it tends to fall off when installing apply a tick coat of petroleum jelly( Vaseline) to help hold it in place while installing. Hope this helps it did it for me
Jun 06, 2011 | Saniflo 013/003/005 Sanibest Toilet with...
Water won't drain from sink or shower and the system is whirring away.
there is a blockage in the saniflo pump or the saniflow outlet pipework
Dec 07, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
Macerator keeps runing even when there has been no flush made or any water down the waste
check level in tank may be to high and not shutting off valve /sticking fill valve /or flapper needs replacing
Jun 24, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
Nov 15, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
It won't stop running
Sounds like the float switch is hung up or burnt out. hope this helps. duane.
Sep 26, 2009 | Saniflo 002/003/005 Saniplus Toilet with...
How to install toilet macerator?
on your out put pipe make sure you put as few turns and bends in it as you can, this will help the pump out when it's grinding and pushing it up. also you will want to use schedule 80 pvc pipe if you can get it and make sure you prime and glue every fitting well because you do not want that to leak when it's started up. it's always good to put a check valve on it as well some where close to where it enters the tank and a shut off valve, the glued pvc valves are handy because you dont have to worry about them leaking
Jul 26, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo Sanibest macerator with multiple connections Logo
91 people viewed this question
Top Saniflo Plumbing Experts
Axel Gringmuth
Vernon Taylor
Gil Shultz
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
