Question about Nokia 6126 Cellular Phone
My nokia 6126 screen is blank
My nokia 6126 was working fine, the battery is fully charged but the screen is blank. white on the outside black on inside, i tried taking out battery and sim card and putting back in, etc. nothing shows up
I have a Nokia 6126 that the screen turns white and the phone resets when I try and open the menu.
Your phone's batteries are most probably worn out. Replace with new one. Ensure you purchase authentic ones from a genuine store and not the local ones. Otherwise, chances are that the problem may still persist.
Jul 25, 2010 | Nokia 6126 Cellular Phone
Nokia 6126 screen is blank
the problem with the screen of your phone is that the flex on the screen of your phone is bad.
All you need to do is just to change the flex on your phone screen and your phone screen will start to display.
Take care
Apr 26, 2010 | Nokia 6126 Cellular Phone
Nokia 6125
If it is shwing some life in the screen then the screen seems to be OK. Hence it should not cost much to repair the circuitry.
Aug 11, 2009 | Nokia 6126 Cellular Phone
My on/off switch doesn't work
We all have the same problem. Our phones too run as long as the battery is charged. Why dont you charge the battery? As regards the on/off switch, get it repaire from Nokia Care or whoever you feel will do a good job.
Aug 10, 2009 | Nokia 6126 Cellular Phone
Screen problem for Nokia 6126
Are you certain you have a strong GPRS signal? Have you tried turning the phone off for a few moments and then back on, and also make sure you have good signal strength at the time you are trying to send an MMS.
 It could be due to network problems as well - the few times I've experienced it, it has lasted for several days and then it has been fine after that.
Nov 22, 2008 | Nokia 6126 Cellular Phone
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Nokia 6126 Screen problem
i have to say, the same thing happened to both of my nokia 6126's.
Jun 04, 2008 | Nokia 6126 Cellular Phone
Camera won't work
take the phone back and have it replaced for a new one.
Mar 11, 2008 | Nokia 6126 Cellular Phone
White lines on razr screen!
you need to replace the flex cable. most likely it was damaged or what not. It proven, test and post replay
Apr 18, 2007 | Motorola Mobility RAZR V3
Nokia 6126 Cellular Phone Logo
265 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
