Back to:
Tags:
GN Netcom GN 8000 Amplifier
Echoing
posted by tja525 on Nov 15, 2007
I read the manual and lowered the number inside the top cover, but my headset is still causing echoing on every single conference call I call into. any other advice?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 25, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you still hear an echo perhaps the your are using a headset with sensitive microphone. Check the specification of your headset
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on echoing:
I don't want to Accept this solution
Solution #2
posted on Jan 21, 2008
Not Rated (0)
jfpogie
Rank:Wiz Wiz
Rating: 82%, 78 votes
lower the volume of your mic.
Thank You!
Can you Help with these Amplifiers and Preamps problems?
my behringer europower pmh660m power amp wont power up...
Am using ps3 with hdmi to TV, TV has no audio out from...
Tengo un equipo de audio marca Philips compuesto de...
Left and right speakers work - centre and surround do...
does the phone handset have to be off the cradle for the...
Loading problems.
Repair Service
Find Amplifier and Pre. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
