Question about Kitchen Ranges
DIGRAM OF HOW THE DOOR HINGE FITS IN OVEN. - Kitchen Ranges
  • pineywoods19 Jul 12, 2009
    woodchuck789, the model number is "KGRT600HWHO".
    when I go to the above link,it just showes where to look for the modle number. Now what?
  • 4,070 Answers
Post your model number and search for the diagram- here-http://www.appliancepartspros.com/modelnumber_locator.aspx
Or post back here and i'll look it up.
Posted on Jul 12, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
How do you fit an oven door to a Hotpoint BD81P oven? My hinges need replacing ?
Go to
WWW.YOUTUBE.CO.UK
In the search box enter---FITTING OVEN DOOR HINGES
You will find some very informative videos on how to fit the hinges.
Dec 04, 2010 | Hotpoint Ovens
Need fitting instructions to replace door hinges as manual misplaced. thank you.
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Oct 10, 2010 | Neff B1421 Electric Single Oven
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 | Ovens
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
How do you remove the oven door?
As there are too many variations to describe on fitting and removing oven door hinges, try this link.
WWW.YOUTUBE.COM.
Then in the search box, type in,---Fitting oven door hinges.
You should be able to find the ionformation you requre here.
Hope this helps.
Dec 25, 2009 | Whirlpool Ovens
Oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Dec 22, 2008 | Ovens
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Kitchen Ranges Logo
182 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
