The door has been checked there is no issues with the door. We did the diagnostic test "damp close" one, "C0" appeared. I have read that no one knows what this means. We replaced our motherboard and it isn't that (200$ later).
SOURCE: Won't start. The start light flashes.
there is a possiblity that the door switch is not working. if you are handy refer to he parts book to see how to remove the switch and check for continuity.
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Testimonial: "Great advice, thank you for your help."
SOURCE: Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
SOURCE: Hello all, My MDE7500AYW Maytag Neptune
looking at schematics looks like you main control board is the faulty part. you have done a very good job of tracing the voltages from the source. been that all voltages are present and door switch is good the part left is the control board. here is the part# 33002886. you can find it at sears website or service center.
good luck to you.
SOURCE: My dryer does not turn on when pressing the
have you checked the door switch this is one of the first pieces that you should check you can actually jump past the switch by takeing a wire and stripping off both ends and inserting each into the each side of the connector. this is the first place you should start checking the next would be the wiring doing continuity tests to the motor from the timer if you have power going to the motor but the motor does not start then you have a bad motor you can test this by taking your multimeter and setting it to check voltage and putting the lead on the hot side of the motor and having someone press the button this requires you take out the entire drum to do this type of test and lastly you would look at the timer for shorted wires or loose connection message me back with your finds personally if you havent checked the dryer switch it sounds like that is your culprit I await your reply as well as if you have any further questions Thanks Rick
