Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at [email protected]
Good luck. Neil.
SOURCE: manual for rascal mobility scooter,
Bub see the following web http://www.rascalscooters.com/index.cfm/mobility/service.manuals
I don't know if they list your model but they have an 800# you can call to get help Hope this helps you
SOURCE: I have a Rascal 245 Mobility Scooter which is 3
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
