Question about Linksys Wireless-G WRT54G Router
How do I put an encryption on my linksys router?
  • 854 Answers
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Posted on Jul 12, 2009
    Genius:
  • 1,269 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Enabling Wireless Security
Step 1:
Access the router’s web-based setup page.
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router’s password ("admin" is the default password), then click OK.
Step 4:
When the router’s web-based setup page appears, click Wireless and select Wireless Security.
Step 5:
Select WPA Personal under the Security Mode drop-down menu.
Step 6:
Select TKIP on WPA Algorithms.
Step 7:
Enter your desired WPA Key on the WPA Shared Key field such as “MySecretKey.” This will serve as your network key whenever you connect to your wireless network.
NOTE: Do not give this key to anyone. This key will secure your wireless network. Leave Group Key Renewal to 3600 seconds.
Step 8:
Click on Save Settings.
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 69 Answers
SOURCE: linksys e3000 router. I am
Open the web browser on your computer and type ''http://192.168.1.1". This address will open the configuration page for the router. When you are prompted for a login name and password to begin configuration, just type 'admin' in both boxes to gain access.
Enable WPA2 Encryption
Under the wireless security tab, enable WPA2 encryption by ticking the appropriate check box. This will encrypt all data that is transmitted over the network. If the data is intercepted by anyone, they will find it to be garbled data. To enable this setting, check out the 'Wireless Security' tab. Choose a long passphrase to use and write it down exactly, because you will have to enter this passphrase on every wireless device you want to connect to to router. (laptop, Wii, BluRay, iTouch, etc)
Posted on May 05, 2011
Coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
Need help putting a password on my linksys
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 12, 2013 | Linksys WRT3000N Wireless-N Broadband...
Have the key but still can't connect to network
The encryption key maybe incorrect. I suggest you RESET the Linksys wireless router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
http://192.168.1.1
Feb 11, 2013 | Linksys WRT160N Wireless Router
I have linksys wrt54g2 and want to put a password on it and dont know how
You need to set WAP or WPA2 encryption to prevent public access.
http://192.168.1.1
Jan 31, 2013 | Linksys Wireless-G Broadband Router
Don't know how to lock my linksys router
http://192.168.1.1
Dec 04, 2012 | Linksys Computers & Internet
I want to know how to put password to my router
If you mean putting WPA or WPA2 encryption on your router to prevent unauthorized access to your wireless network/Internet then -
http://192.168.1.1
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Nov 23, 2012 | Linksys Computers & Internet
How will i change the password of my WAG200G router,and how can i access my linksys to change password
Do you mean the router's login password or the encryption password?
http://192.168.1.1
Aug 27, 2012 | Linksys WirelessG ADSL Home Gateway...
Connect macbook to linksys wrp400
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
http://192.168.1.1
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2012 | Linksys WRP400 Wireless Router
Trying to use belkin router with linksys adapter cards..do i need new drivers
You need to configure the Belkin router with a SSID and WAP or WEP encryption, Then install the Linksys adapter driver in the computer and then configure the Linksys adapter with the Belkin router settings (ie. the SSID and encryption) before the Linksys can communicate eith the Belkin router.
Aug 02, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Encryptiing
Is your router from linksys also? How many wireless computers do you have? Note that if you encrypt your router, you need to make sure that each wireless computer gets the exact encryption keys you will use on the router. Usually the linksys router page can be accessed via http://192.168.1.1. Leave username blank, password is "admin". Go to Wireless >> Wireless Security. Select WEP-128 key. Enter in a passphrase and hit generate. Copy key #1 on a piece of paper (make sure it's 26 characters) and click apply. Next, go to each wireless computer and use encryption key#1 when you connect to the linksys router.
Jun 19, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Linksys Wireless-G WRT54G Router Logo
413 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
