Question about Speed Port-A-Cool 16" Evaporative Cooler Direct Drive Variable
The Mastercool cooler is not cooling. It is only
The Mastercool Plus evaporative cooler is not cooling. It is only slightly cooler than outside. How can I find out if the pump is working? The "Speed Port-A-Cool" was the closest I could find to the product I have.
  • 92 Answers
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Posted on Jul 13, 2009
Mastercool plus 6500 thermostat problem
Posted also on the Cooler quick cycling problem:
My Master Stat Controller (CC2000A Rev 2003) was in 2 parts. The Thermostat unit in the house and the Power Control unit in the Cooler. The power Control unit was mounted on the squirrel cage fan housing so it vibrated some when running. That means the components vibrated slightly with respect to the PC board. Especially the larger components. My first symptom - Intermittent failure to turn the water pump on. I could see a faint crack in the solder around the pin of a relay on the PC board. Re soldering the PC pins solved that problem. Later, the second symptom was quicker than usual on-off cycling of the fan. I re-soldered all the pins on the PC board and all problems subsided. A better mounting place for the Power Control Unit would be good, but outside of the cooler might be a thermal problem here in the hot desert south west.
Apr 24, 2012 | Mastercool 67471 Evaporative Cooler Air...
Would reflective foam covering the outside of my matercool help it cool better?
No! The unit needs air flow across the grills for it to cool properly. But your unit should be shades so an awning over it would help. We use a piece of camoflage netting over ours and it seems to help quite a bit.
Jul 22, 2011 | Mastercool 67471 Evaporative Cooler Air...
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
My evaporative cooler is only blowing warm air through the home, even though the water is on and all windows are open. Can you help?
Check if the water is getting into the unit. check if it is pumping any water over the filters. cooler will meet its limits at 90% humidity plus
Dec 31, 2010 | Mastercool 67471 Evaporative Cooler Air...
Need to know the difference between a master cool and a ultra kool
They are pretty must the same design, the Mastercool was made with heavier metal. But Mastercool are no longer being made,,,, so I guess if it's a new one you are looking for,,, Ultra Cool it will be.
Good Luck,
Paul
Mar 25, 2010 | Mastercool 67680 Evaporative Cooler Air...
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Sep 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Speed Port-A-Cool 16" Evaporative Cooler Direct Drive Variable Logo
209 people viewed this question
Top Speed Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Speed Plumbing Expert? Answer questions, earn points and help others
