Question about Sony Bravia KDL-42V4100 42 in. LCD TV
Is GONE pufff.It flashes 6 times and thats about it NOTHING is there a way to check on it
  • 439 Answers
This usually means the lamp or the ballast that powers the lamp is bad.
Posted on Jul 11, 2009
    President:
  • 563 Answers
The only way to check on it is to have it looked at by a TV repairman. There is a part that needs to be replaced, that I can tell you for sure. This isn't a problem that you can fix with troubleshooting. If the unit is under warranty, the repair will be free. If it isn't under warranty anymore, you will have to pay for the repair.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Samsung tv un50eh6000fxza...has standby power but some times takes several tries to start. When it starts led flashes 6 times. When it wont start led flashes 2 times after 15sec from pressing power.
This is usually caused by some tubular capacitors that have gone bad. You can tell visually by the fact that the bad ones have started to swell up. You can check the value for voltage and microfarads and buy replacements at Radio Shack or similar electronics store. While the microfarad capacity has to be the same, the voltage can be the same or higher.
Mar 09, 2015 | Samsung Televison & Video
Bike won't start
Flashing is a signal to display DTCs that are set
Apr 14, 2014 | 2005 Harley Davidson XL 883 Sportster
Light blink 6 times
Your mainboard is gone bad, happened to my tv and they had to replace it.
Oct 09, 2012 | Sony KP-53HS30 53" Rear Projection...
When my nat. gas boiler kicks in, there seems to be a small build up of gas, it pufffs, not everytime. Would a bad thermocouple cause this?
I don't suspect the thermocouple, I suspect either a dirty pilot, dirty main burner(s) or gas pressure. Try cleaning the burner areas with a good brush. If it continues, have the gas Mainfold pressure checked and you may end up replacing the gas valve if none of the above helps.
Jan 20, 2011 | Heating & Cooling
My 1997 Dodge mini van will not start. When I do
The flashing check engine light would mean that the engine is misfiring, If you have a scanner, use it on the diagnostic port of the engine to check for the error code to get which cylinder is misfiring and if there are other errors that needs to be checked.
Jan 19, 2010 | 1997 Dodge Caravan
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Fd trintron won't turn on standby flashes 6 times I have done a hard reset and it worked for a couple of times and is gone again
There are some IC's in the power supply that are going bad. This is a pretty complicated repair. You may want to have a repair shop check it out for you. Thanks
Nov 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
What could be wrong ?
Hi Please check your manuel I think this is an indicator that your bulb may have gone , usually with most projectors this is what a red flashing light means . At the price they are | hope for your sake I am wrong but I dont think so Sorry .. regards vortash
May 13, 2009 | Sony Televison & Video
VCR does not record when programmed to do so
is there a option to turn timer rec on/off?
Oct 20, 2008 | Televison & Video
Sony Bravia KDL-42V4100 42 in. LCD TV Logo
221 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
