Question about Refrigerators
I have small scratches in my whirlpool fridge is there anything that would smooth them out
  • 4,070 Answers
Very fine grit sandpaper will but it will remove surrounding pain and you would have to get some touchup paint.
Posted on Jul 12, 2009
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Whirlpool fridge freezer stopped making ice
Make sure the freezer plug cord has power on the outlet. Also check the thermostat control if working, in desired settings especially in low degrees, it should have some freeze. If not, then thermostat is defective.
See to it that the evaporator has no dent, punctured cause by sharp object ( knife, screw driver, etc.) when removing frozen food or drinks. If it has small hole, it will cause refrigerant to evaporate hence freezer will stop making ice.
A defective defrost timer will also cause that same problem. You will know it by dialing the knob, it should smooth and no friction and if it has failed to go back to original position.
Thanks for asking.
Jul 03, 2011 | Whirlpool Refrigerators
How do I fix the crack in liner of my fridge. its getting more all the time. is there something wem can but to fix it?
If you are a little bit handy, fo to your auto parts store and get a small fiberglass body repair kit. Read the directions. Make sure you have the edges of the crack smooth and level with each other. Cut a piece of the cloth that comes in the kit that will cover the crack. Carefully mix the resin and hardener that comes in the kit. Then working quickly spread it smoothly over the cloth. Let it set up and sand smooth with 120 grit sand paper. If you want to try to match the interior color of your refrigerator, you could spray paint just the area that you patched.
Sep 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool american fridge freezers water dispenser is continually dripping what can I do to resolve this problem
Replace the water inlet valve , the piece that the wall water line connects to on the refrig .. Something like a grain of sand , piece of dirt etc , is caught in the rubber bellows , not letting the valve close completely . This will cause a scratch , which will collect anything else that comes thru , so cleaning it out will not work . ( it won't remove the scratch ) .
Sep 06, 2009 | Whirlpool Freezers
SCRATCHED CLOUDY DOOR WINDOW
plastic on acrylic.
now this is going to be a time consuming task.
use a small soft rag little water, go steal a tube of tooth paste and go to work. basiclly you are going to polish the windows, since acrylic is softer than glass, you can't use mechnic tools, you going to burn a hole.
good luck!
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a whirlpool (IKEA) CBI 651 fridge/freezer, the condensation drain on the back wall of the fridge part is not draining away the water. Have tried to clean it out with red 'widget' supplied with no...
Try pouring some boiling hot water down the drain. If anything blocks the drain even slightly it will slow down the water and then freeze it. Air temp in the freezer is 0 degrees or close to that. That small of a hole it freezes quick. I'm not sure of the style of fridge this is. Side by side or top mount freezer. You are able to get to all drain pipes. If not boiling water. A hand steamer works great too.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
Jan 20, 2018 | Whirlpool Refrigerators
760 sedan scratch
It depends on how deep the scratch is. If it's shallow and only into the clear coat, it can generally be buffed out with compound and you'll never see it. If it's deep to the touch and goes into the paint to where you can see metal or undercoating the you will have to have it sanded down, smoothed out and repainted.
May 14, 2008 | 2007 BMW 760Li Sedan
Scratch on stainless steel Kenmore fridge
brillo a little harsh, finer steel wool would be better ive even used the scour side of the sponge, using wd40 as a "cutting oil" lightly go over scratched area. look close and follow the grain of the S/S. just likje wood S/S has a grain direction
Feb 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool Side-by-Side Fridge
unscrew the cover plates on the top door hinge there are quick connects for the elects and 3 bolts on the freezer side and just 3 bolts on the refg side before you removed the freezer door pull the kick plate and there is a water line quick connect you will need to disconnect it as the tube runs thru the hinge after the top bolts are out pull up on the door and it is off >>>Note: there are some small plastic washers on the hinge post make sure you dont lose them
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
