There is a folder with a ? on it flashes blue and white faces and the ? what is wrong it just keeps flashing between the two
Belkin n450 db keeps flashing orange to blue and won't connect to internet
This flashing of Orange to Blue Light can happen due to several reasons. Some of them like Overheating of Router, Wrong Connection, Hardware or Software problem and etc. If you are going through this problem visit at this site Belkin Support Belkin Router Support Number 1 800 335 8177 Belkin Help They will help you to solve this kind of problem.
Jan 21, 2014 | Belkin N450 Wireless N Router
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
My Mac Book will only go as far as a blue screen with a folder flashing a question mark. What does this mean?(also there's a ticking sound near the DVD drive when i first start up)
The DVD ticking sound is normal and happens every time you power on. The blue screen of death is not normal. The flashing question mark means corrupt start up file. Re-install the operating system or insert disc 1 of your gray install disc and go into disk utilities and select repair permissions. Then select repair hard drive.
Oct 19, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
On start-up I get a white screen and then a flashing file folder
Your Computer can't find a system to boot (?), so you need to boot from your CD. Once booted from the CD, run Disk Utilities to see what's wrong. If it sees the drive, then repair it, fix permissions, if it does not see the drive, then it might have gone south. If it can't be repaired, then you will need "DiskWarrior", to see if it can fix it. If you have a current Backup
Sep 28, 2009 | Apple Computers & Internet
Computer won't work & shows a file icon w/a"? and a smiley face"
the "?" and the "smiley apple face means it couldnt find the osx to boot from. this can be cause by a bad or deleted file or a failing / bad harddrive. it sounds like a bad harddrive since it doesnt find the destination.
Dec 30, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple g4 ibook 12' wont show o.s.
You probably need to reinstall the OS. That would be the best thing to do,so you would not have to mess with the data that is on the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Apple iBook Mac Notebook
Flashing Folder
you are having main-board issues and possible harddrive issue.
but the mainboard can cause drive failures your info might be fine,The blue screen indicates a board error(memory usually)
Aug 09, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Flash
i rally dont know, i personally always keep my flash on auto and keep the brightness auto or 50%. if this is the case, then i strongly recommend contacting Sony and asking them for a solution, or taking it down to the store you purchased it from and asking them to fix it or refund it!!!
hope this helps and sorry i couldn't help in much detail!!
keep in touch and tell us how its going
Dec 22, 2007 | Sony Cybershot S650 Digital Camera
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
