Question about Brother DCP-7020 All-In-One Laser Printer
Brother DCP all in one laser printer
When I print, the right side of the page is very light even on the darkest setting
this just started happening
I have replaced the drum, replaced the toner...
any suggestions?
    President:
  • 4,402 Answers
Http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000099/faq000699_000.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=3
Posted on Dec 20, 2007
Printed copies at the right side comes out faded
http://www.support.easyink.co.nz/mfc-9440cn-no-printing-on-left-or-right-side-of-page/
No, the above page is not for your exact printer model. But the "clip" problem may be at the root of your problem. Yes, this clip may have been loose for some time.
Other issues, see:
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=dcp7065dn_all&ftype3=1975&faqid=faq00000151_031
May 11, 2015 | Brother DCP-7065DN Multifunction Laser...
BROTHER DCP-7065DN HOW TO REPAIR LEFT SIDE VERY LIGHT PRINTING
When this occurs it usually means that the toner cartridge is running out of toner on that side. The left is most common since most printing is on that side. Remove the toner cartridge, and shake it vigorously from side to side for a few second, then replace and try again..
Apr 14, 2015 | Brother DCP-7020 All-In-One Laser Printer
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
How to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Jan 13, 2010 | Brother DCP-7040 Laser Printer
Brother dcp7010 all my printed pages have 4 dots on right hand side how do i get rid
If this 4 dots have equal positions from page 2 page: *replace OPC or replace drum unit
If this 4 dots have non-equal positions from page 2 page:
*do Preventive maintenance for your Brother
Oct 16, 2008 | Brother DCP 7010 Multifunction Laser...
Printing slanted
Look at the paper tray and make sure the guides are aligned properly. Most of the time, there's nothing you can do except make sure the paper stack is arranged as evenly and as tightly as possible. I've found about a .05" variation in mine that leaves room for the paper to slant. So much for manufacturing tolerances..
Jul 01, 2008 | Brother DCP-7020 All-In-One Laser Printer
Page printed crooked
Ensure paper edge guides on paper cassette are set to correct paper size ie .against edge of paper.
Dec 26, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
142 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
