I have used silicone sealant which just lubricates the surface between the rubber hose & plastic outlet which makes the hose slip off. The hose clip will not hold the hose in place and it keeps slipping off during the pump out cycle. Is there a proprietary adhesive that should be used to help hold the hose in place?
SOURCE: drain pump
My husband did remove ours,and we too have a frigidaire 18" built in dishwasher. But ours won't drain, he says it might
be the pump, but he is hoping not.. everything works except when its draining. water just sits there in the bottom.. He took it apart and cleaned everything, but still the same issue.. Any suggestions for me will help also.. TY< PAMMIE
SOURCE: Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
SOURCE: How to remove a sink, sealed with silicone
Try using a long piece of dental floss, like a saw, all the way around until you cut through the silicone.
SOURCE: belt was slipping (sticking) lubricated
check the tention on the w/belt.after that check the drive motor belt if you find lots of black powder your belt is worn out. it dose not have the grip to move the front roller
