to be a little more specific I am looking for the RMS Power Rating at 4 ohms x2.(in wattage)to be a little more specific I am looking for the RMS Power Rating at 4 ohms x2.(in wattage)
You can't post conmments that contain an email address.
Re: need RMS rating for 1200w audio tek 2 channel car amp
Wikipedia.com "Root mean square" can be calculated with known values of your amp...not sure why you would need this info as all VDC are generally assumed 12.7RMS
This Kicker Amp will compliment them JL Audios like nothing else. KICKER ZX Series ZX350.4 4 channels all rated @ 75 watts RMS. If it was me that would be my choice for a replacement amp.
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class
X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS
@ 1 Ohm Mono
1 x 650W RMS @
2 Ohm Mono
1 x 500W RMS @
4 Ohm Mono Fully Unregulated MOSFET Power
Supply 2 Ohm Stable @ Mono 1 Ohm Stable @ Mono 0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
