Question about ASUS Eee PC 900 PC Notebook
ASUS Eee PC will not boot (blank screen)
ASUS Eee PC running XP will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are on. The computer will not start.
3 Suggested Answers
camille zar
  • 95 Answers
SOURCE: I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: Asus Eee pc 900 can't boot (blank screen)
I had the same problem and from other forums I found that you have to remove the memory and short cmos . To short cmos I use screw driver to connect two copper pads.
Posted on Sep 11, 2009
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
Asus eee pc 1005hab will turn on but will not boot up. cannot get into bios vis f2, esc. just a frozen screen that says asus eee pc press f2 for bios. I have disconnected the battery many times, will not...
I have an Asus Eee pc 2g surf. I inadvertently installed a bios 2008 upgrade and cannot provide a password and cannot get beyond this page. Assus techs cannot provide it without an invoice and I have none as it was a gift. Any solution? I have taken out the battery, pressed f2, shift f10 ( which gets me to a screen "Atheos Boot Agent Configuration Agent" but not sure how this will help)
Jan 19, 2011 | ASUS Eee PC 2G Surf Notebook
Hi! i have an Asus 1000h eee pc. When i start it, the screen just goes blank. the battery led is on and i can hear the fan running.im not getting any sound like in the background windows is booting.And...
Hi there, I had and have the same problem since I bought.It went to Asus to repair and 1º time, 1 month later, they said it was a fault in the camera, and replaced it. Bah!! the 2º, 3 month later, it was the OS and reinstall it the XP. Bah!! bullS" the 3º time they update the BIOS which worked until now, but the reality is that it was just a lucky, it is for sure the BIOS or chipset problem. Mine occurs when I am running on battery and with the WIFI and Bluetooth on and the battery runs out, either the XP tries to hibernate or suspend mode and after that it show the same problem as you describe. - I know it does help you but it might give more hints for who understands.
Aug 24, 2010 | ASUS Eee PC 1000HE Netbook
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are...
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Jun 02, 2010 | ASUS Eee PC 900 PC Notebook
My eee pc 900ha is powering up but nothing is happening with the screen, the power light comes on and the hdd light blinks once but thats it. I have tried what their tech ppl suggested and taken the...
plug in the battery and power cord ...
switch on the pc .......by pressing the power on button
and after 30sec keep pressed the power on button until it shuts down and then restart and check...........
Oct 02, 2009 | ASUS Eee PC 900HA Notebook
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
hello
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
ASUS Eee PC 900  PC Notebook Logo
4,031 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
